Strange issue with FHD over VGA (X61, Windows 10 - works in ubuntu)
iamdmc
Hello fellow ThinkPadders & X61 lovers
Has anyone gotten the X61 (965 express / X3100) to play nice with Windows 10?
THE PROBLEM: I'm trying to drive an external 1080P LCD from my X61 by VGA on Windows 10, but I get black bars on the sides (not full 16:9 widescreen)-likely due to hsync or vsync issues but I can't figure out how to fix. It displays in widescreen at 1680x1050 with no black bars.
Strangely, it outputs correctly when viewing the Windows 10 desktop through a remote desktop (Anydesk) so it's definitely a VGA-related issue, but a software one rather than hardware because... It works perfectly on Ubuntu 20.04 - no config needed.
CONNECTIONS (panel to X61)
1080P LCD --- eDP board with HDMI --- VGA out from X61 to HDMI into the eDP board using an active VGA to HDMI adapter
I've also tried several active VGA to HDMI adapters, replicating the same issue on Windows 10 but working perfectly on Ubuntu 20.04
Please let me know! And thanks for reading
I've tried every 965/945 express and X3100 driver that I could find and nothing has worked in Windows 10. Any ideas?
ThinkPad X1C gen10 (2023)
i5-1235U | 16GB RAM | 2TB Samsung 990 Pro | QHD OLED
The X61 is dead... long live the X61
Past * current IBM (&lenovo) ThinkPads: X1C12, X1C10 P14s gen2, T480s, T450s, X250, X230, X220, X300, T410, X61s, T60p, T41, X31, T23, A21m
Re: Strange issue with FHD over VGA (X61, Windows 10 - works in ubuntu)
I suspect it's that nasty thing that W10 does where, instead of actually applying the resolution you select to the display, it scales it to what it thinks is your native resolution.
When you are in the resolution selection, there is this link called something like "Display adapter options", something with advanced adapter options, basically. You are searching for a button called "List All Modes" on the "Adapter" tab. Try selecting your resolution from there, if it is already selected, go back and fourth between two resolutions. This should hopefully fix it. I think changing your resolution from the Intel control panel should also go around this.
X40, T60 (ATI X1300), X61 (melting), T61 (Nvidia NVS140
), X201 (main), T420, T430 (beheaded) - Windows 7 homebrewer and fanatic, Debian enjoyer.
iamdmc
thanks for your replyFierelier wrote: ↑Fri Oct 01, 2021 12:24 amI suspect it's that nasty thing that W10 does where, instead of actually applying the resolution you select to the display, it scales it to what it thinks is your native resolution.
unfortunately, that doesn't help. It seems to be an Intel GMA driver issue on Windows 10. It works perfectly out-of-box in linux
See if the Intel control panel is set to use the panel for scaling instead of the GPU ("Maintain aspect ratio" and whatever), if that is a thing. If that doesn't help, maybe try making a custom resolution in there. Thinking 1920x1080 59hz?
iamdmc
Thanks - I tried making custom resolutions in "custom resolution utility" but it was no help. There was no such option in the "list all modes" window
Think this will need Linux as the fix
List all modes should be a thing, unless it was recently removed. In the W10 display settings, you press "Change adapter settings", and then from there you should be able to list all modes. If it's not a thing, it could have moved slightly. But yes, you will be better off with Linux on that machine either way. If you don't need to use Windows 10, don't use it.
[WTB] Thinkpad x61 battery (battery life doesn't matter as long as it works)
by Redaa » Sun Jan 25, 2026 6:08 am » in Marketplace - Forum Members only - 2 Replies
- 6096 Views
Last post by Redaa
Sun Jan 25, 2026 6:27 am
LCD IAXG01M works in x22, with caveats
by blegas78 » Sun Nov 02, 2025 7:28 pm » in ThinkPad X20/X30/X40 Series incl. Tablets - 3 Replies
- 7289 Views
Last post by Plunkyy
Wed Dec 03, 2025 8:31 pm
- 4 Replies
- 7387 Views
Last post by dcfbf
Fri Dec 12, 2025 2:40 am
T530 Screen Upgrade to FHD Panel - Which Panel?
by Silverlake » Wed Dec 17, 2025 3:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 0 Replies
- 8724 Views
Last post by Silverlake
Users browsing this forum: No registered users and 69 guests
