T420/Bought new palmrest without touchpad.
KenKaniffer
Hello fellow ThinkPad users, I have an old T420 That I use as a daily driver. The problem with it is that I bought a new palm rest but without noticing it, bought one without the electronics (mousepad, buttons...) Is there a way to remove the mousepad from my old palmrest and attach it to the new one or am I stuck with a part that I have no use for ? Thanks for any replies
theterminator93
Re: T420/Bought new palmrest without mousepad.
I don't recall the T420 having a removable touchpad like the X220s do. If you're referring to the textured part of the touchpad, it's just a sticker. It will work just fine without the sticker.
The recovery sets guy
KenKaniffer
No, I dont mean the sticker, I mean the whole botton of the touchpad part has electronics and the new palm rest has only plastic hollow part where the touchpad is supposed to be.
Re: T420/Bought new palmrest without touchpad.
Never done it on a T420 but I don't see why you can't re use the stuff in your previous palmrest to make the new one complete.Just the usual recommendation to do it carefully to avoid damaging the parts. And to spend some time studying the process before doing anything. Thinking ahead saves you headaches.
I'm fixing to do the same thing, that is replace the mouse pad, but...
You need to buy the palm rest with the pad installed with the ribbon.
The pad is glued to the palm rest from what I understand.
I'm now trying to buy a "parts only" T420 to get what I need because everything else I see is from CHINA and shipping is screwy now with the COVID Scam!
Bought a secondhand Thinkpad X201t, have repair questions
by obelisk » Thu Feb 05, 2026 5:34 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 2 Replies
- 3108 Views
Last post by obelisk
Fri Feb 06, 2026 9:47 am
Just bought a T510 with i5-540M
by ShellieACarlson » Sun Feb 08, 2026 12:29 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 2484 Views
Last post by lurespend
Mon Apr 20, 2026 11:34 pm
Will X220 Tablet palmrest fit X230 Tablet?
by tts_rayhan » Sat Feb 07, 2026 7:28 pm » in ThinkPad X230-X280 / X390 Series - 0 Replies
- 4280 Views
Last post by tts_rayhan
Disable Touchpad on ThinkPad T490?
by Clueless in Seattle » Tue Jan 20, 2026 9:57 pm » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 4784 Views
Last post by dcfbf
Sun Feb 08, 2026 1:41 am
