I found my laptop switched off and the plug of the charger had fallen out of the wall socket.
When I put it back it was very loose so I guess that's why it fell out.
However, after putting it back the LED next to the power connector on the laptop wasn't lit.
So I found a reliable extension wire, plugged in the charger, but still no LED.
Then I tried to switch on the laptop and saw the LED next to the power connector's input blinking orange/yellow shortly.
That didn't look good, so I switched off the laptop again.
Measuring the charger's voltage gave me 19.7 V, good enough I think, and the resistor between the pin and the zero on the 170 W (20V, 8.5A) charger's power connector gives 1.75 kOhm, which also looks alright according to thinkwiki .
So now I'm afraid there is something wrong inside.
Has anybody here experienced (and solved) the same issue before?
Hints would be welcome.
P71 not charging
Re: P71 not charging
The battery is probably completely discharged.
Remove the battery, then try again with only charger.
If OK, put the battery back in and leave it charging overnight.
If still not charging after that, get another battery.
Thanks man, it runs without a battery.
Will now charge it for a night and will see what it says (battery status) when I start it up again.
If still low hopefully indeed only the battery. It is now 4 years old, but was still going strong...
FS: ThinkPad P71 Xeon workstation
by PiZzA EnGiNeEr » Sat Dec 06, 2025 10:25 pm » in Marketplace - Forum Members only - 1 Replies
- 3159 Views
Last post by positive
Sat Dec 20, 2025 4:19 am
GPU upgrade in a P71
by lyricalvanity » Wed Mar 25, 2026 10:50 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 1 Replies
- 1125 Views
Last post by Section13.us
Mon Apr 20, 2026 6:58 pm
FOUND: WTB Lenovo Thinkpad P71
by Section13.us » Fri Apr 10, 2026 12:16 am » in Marketplace - Forum Members only - 1 Replies
- 531 Views
Mon Apr 20, 2026 6:52 pm
Battery use and charging etiquette for Classic ThinkPads?
by johnny1093 » Wed Oct 29, 2025 1:50 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 2 Replies
- 14978 Views
Last post by johnny1093
Sat Nov 01, 2025 8:46 pm
