L512 Dispay replace FHD problem
Hi, i bought a B156HW01 V.7 FHD panel. Installation works fine and brightness regulation in Win10 works too.
But i have some stupid image quallaty, in post screen black is not black but its light green see images.. what are the diverences between v0 1 2 3 4 5 and V7 displays? I found nothing
https://ibb.co/JCqJnRg
https://ibb.co/1fYSB2g
https://ibb.co/nLC9yD7
kfzhu1229
Re: L512 Dispay replace FHD problem
If it works perfectly fine in Windows after you have the graphics drivers installed (and shows the same problem without the graphics drivers), this would be an EDID compatibility problem.
I had this on a Dell laptop before where I replaced with the WSXGA+ screen coming out of an MSI laptop, and the same problem occurs but it's perfectly fine in Windows with the graphics driver working properly.
Curiously enough, I tried the same screen on the same laptop but the integrated graphics version, the problem is not present.
I guess the solution would be to modify the EDID information of the panel, or swap the panels with another laptop. Maybe that other laptop won't have this compatibility issue with this panel.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
its not a grafics driver problem cause i have this problem in bios also
kfzhu1229
As I said, EDID compatibility problem, and this is if under Windows after the graphics drivers are installed, the issue disappears.
UXGA:
UXGA:
The drivers are installed i also flashed the new diwplay sucessfully with a lenovo cpompatible FHD Dispaly but nothing changed maybe i damaged the display cable. I will swap back to old display and see if the image gets good again
i figured out the display cable is ok.
Edit: I found out i have the wrong display cable for FHD i actually have the 45M2857 but in the forum i read i need 45M2859.. I ordered it an hope it works
UPDATE: I changed the Cable to "75Y5628" this should be the same like "45M2859". Can someone verify that?
I still have the same Problem. bad image quality and a light green touch instead of dark black in post screen
T530 Screen Upgrade to FHD Panel - Which Panel?
by Silverlake » Wed Dec 17, 2025 3:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 0 Replies
- 5964 Views
Last post by Silverlake
FHD IPS for T520
by TP_ » Mon Feb 16, 2026 1:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 2807 Views
Last post by dcfbf
Mon Feb 16, 2026 3:41 pm
FS: T520 FHD $70 continental usa
by TPFanatic » Wed Mar 04, 2026 5:56 pm » in Marketplace - Forum Members only - 0 Replies
- 1715 Views
Last post by TPFanatic
- 0 Replies
- 2071 Views
Last post by Meteor
Wed Feb 25, 2026 7:58 pm
