T520 CPU upgrade
- Location: Bracebridge, Canada in the deep woods of central Ontario
T520 CPU upgrade
I scored a free T520 today - woo-hoo!
It's a fairly base unit with the cheap display and an i5-2520 CPU.
My questions are:
Will any T520 run the quad core CPUs?
If so, is the performance improvement with an i7-2820QM (for say .. light video editing with an external monitor, SSD and 16GB RAM) enough to warrant the $90 cost of this CPU?
My questions are:
Bill
____________________________________________________________
T61 - X201 - Edge 15 - T520 - X131e - X230 - T440 - X250 - T450 - T480
Re: T520 CPU upgrade
For what you are proposing, personally I wouldn't bother. Rather spent that money on a cheap desktop. Biggest problem with laptops is the cooling. CPU/GPU intensive application will put out a lot of heat with an i7. Plan on upgrading the CPU cooling too.
For even more performance, you could flash the BIOS and put in an Ivy Bridge CPU.
Thinkpads
R51 1829-W1C 2GB RAM
R500 2716-RY6 8GB RAM
T520i 4239-47U, 16GB RAM
T530 RIP
T480 20L6 24GB RAM
SK-8835 Ultranav keyboard Japanese layout
T530 RIP
T480 20L6 24GB RAM
Have a look at this 1-litre size Lenovo M900 Tiny desktop: https://www.ebay.ca/itm/185135122718
Needs a CPU, RAM, SSD, external keyboard, external monitor.
Fantastic little machines!
Yes the T520 will readily run the Quad core CPU's, but if you really want a quad core I wouldn't go for the 2820QM. Step down a notch or two and settle with something like i7-2720QM. The extra bit of max all core turbo frequency is going to be completely extinguished when any kind of GPU load is on the side, pushing the CPU to thermal limits.OneByteCPU wrote: ↑Thu Feb 03, 2022 8:47 pmWill any T520 run the quad core CPUs?
But for your usage, it seems too desk bound and I would agree with others' recommendation of getting a desktop of that era instead. Spending C$90 on something like an OptiPlex 9010 or HP Compaq 8300 Elite is going to crush what you are going to get this thing to do in terms of desk bound video editing, with PCI express graphics cards, max 32GB RAM, i7-3770 and more hard drive mounts.
So maybe you are better off sticking with that i5-2520M. You actually don't know how the i5-2520M is good enough for most things until you work on a bunch of laptops with Sandy bridge Pentiums and i3's and wanting to get i5-2520M as sensible CPU upgrades
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Thanks everyone for your input. It sounds like if I do the upgrade it will be for 'enthusiast' effect only.
I'll keep my eye out for a reasonably recent (and reasonably priced) workstation ThinkPad for my video needs. I can always use another ThinkPad as I only have 9 as it is.
Have a great weekend!
Bill
Nothing wrong with upgrading just for the sake of upgrading. No rhyme, reason nor does it make financial sense. Heck I do it plenty of times and not just on PC and laptops.
This looks interesting. Maybe I'll send the vendor an info request. I have a 7th gen i7 laying around waiting for a place to put it and I wonder if it would fit in this.RealBlackStuff wrote: ↑Fri Feb 04, 2022 12:44 amHave a look at this 1-litre size Lenovo M900 Tiny desktop: https://www.ebay.ca/itm/185135122718
Bill
Here are a few CPUs that fit in the M900 (mine has the low-TDP i5-6600T):
00XG111 N Intel Core i3-6100T 3.2GHz 35W
00XG112 N Intel Pentium G4500T 3.0GHz 35W
00XG114 N Intel Pentium G4400T 2.9GHz 35W
01AG002 N I I7-6700T 2.8GHz/4C/8M 35W
01AG003 N I I5-6600T 2.7GHz/4C/6M 35W
01AG004 N I I5-6500T 2.5GHz/4C/6M 35W
01AG005 N I I5-6400T 2.2GHz/4C/6M 35W
01AG016 N Intel Core i3-6300 3.8G 2C
01AG017 N Intel Core i3-6100 3.7G 2C
01AG019 N Intel Pentium G4500 3.5G 2C
01AG020 N Intel Pentium G4400 3.3G 2C
01AG022 N Intel Celeron G3900 2.8G 2C
01AG023 N Intel Core i3-6300T 3.3GHz 35W
01AG040 N Intel Core i7-6700 3.4G 4C
01AG041 N Intel Core i5-6600 3.3G 4C
01AG042 N Intel Core i5-6500 3.2G 4C
01AG043 N Intel Core i5-6400 2.7G 4C
01AG044 N Intel I7-6700T 2.8GHz/4C/8M 35W
01AG045 N Intel I5-6600T 2.7GHz/4C/6M 35W
01AG046 N Intel I5-6500T 2.5GHz/4C/6M 35W
01AG047 N Intel I5-6400T 2.2GHz/4C/6M 35W
03T7443 N Intel Core i5-6600 3.3G 4C
03T7444 N Intel Core i5-6500 3.2G 4C
03T7445 N Intel Core i5-6400 2.7G 4C
03T7446 N Intel Core i7-6700 3.4G 4C
Unfortunately I don't have any of those. I have the i7-7700. Thanks for the info though.
Bill
Is Coreboot required to install Ivy Bridge CPU in T520 with dedicated graphics?
by dcfbf » Mon Jul 21, 2025 8:07 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 1 Replies
- 1381 Views
Mon Jul 21, 2025 9:45 pm
Is CPU Upgrade on x230t Worth It Performance-Wise?
by ArchiMark » Tue Jul 08, 2025 5:48 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 6 Replies
- 1756 Views
Last post by ArchiMark
Wed Jul 09, 2025 1:13 pm
T520 battery questions
by steveadorjan » Wed Aug 20, 2025 5:15 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 1551 Views
Last post by steveadorjan
W520/T520 Replacement Screw Cover Stickers for Monitor Casing?
by jacqylfrost » Fri Sep 12, 2025 5:55 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 1 Replies
- 857 Views
Sat Sep 13, 2025 1:03 am
