T420 ? Installing Win10; preserving Preload/Win7 Recovery Partition/Preload ?
null_unit
#1 Post by null_unit » Fri Feb 18, 2022 2:04 am
Quick question: is there a way to install Windows 10 onto a T420 while preserving the the Windows 7 Recovery Partition/Preload?
... and if not, what's the best way to backup the OEM Win7 install and recovery partition?
T460s 20F9 i7-6600U vPro·GeForce 2000m·IPS FHD
T440p 20AN i5-4300M·NVIDIA GT530M·IPS HD+
T540p 20BE i7-4900MQ·3K
X1 Carbon Gen 9 i7-1185G7·Iris Xe·IPS UHD+
11e Gen 2 AMD E2-6100 APU·Radeon R2-HD
T430 | T420 Optimus | T410 | T520 | T510
T43p | T42 | T23 | X20 | 600X
Re: T420 ? Installing Win10; preserving Preload/Win7 Recovery Partition/Preload ?
#2 Post by dr_st » Fri Feb 18, 2022 11:22 am
I think that if you don't touch / don't format the Win7 preload partition, and install Win10 to a different partition, it will preserve it. It may become non-bootable, because a different partition will be marked 'active', but this is just a flag and can be reverted at a later time should you wish to restore your Win7 environment.
Users browsing this forum: No registered users and 70 guests
