T61 9 cell battery DOA, any suggestions?
T60/T61 Series
CompanyChoam
#1 Post by CompanyChoam » Thu Mar 24, 2022 7:23 am
I bought a NOS genuine Lenovo 9 cell battery for my T61, and unfortunately, the battery won't charge in either of the T61s I have, I get the fast blinking orange battery indicator light.
I was told that I should check the SMBus info but from what I gather, this is something you can't do with a piece of software on the laptop and requires you use another piece of hardware to accomplish this.
Assuming that method doesn't work, is it possible to re-cell the 9 cell battery for these laptops? I haven't found any specific information on doing it for this particular battery, nor anyone who reported even attempting it and whether they had success or failure doing so.
TPFanatic
Re: T61 9 cell battery DOA, any suggestions?
#2 Post by TPFanatic » Thu Mar 24, 2022 7:46 pm
Is this a 14" wide T61, or a 4:3 or 15.4" T61?
14" wide T61 can share batteries with T400, and 4:3 or 15.4" T61 share with the T500. You may have luck searching for one of those slightly newer batteries.
Otherwise recelling and aftermarket are the remaining solutions.
kfzhu1229
#3 Post by kfzhu1229 » Fri Mar 25, 2022 7:33 pm
Try to install the ThinkPad power manager and see what voltage shows up in the battery details. If it is under like 8V chances are it will never charge up again and that would be indeed dead
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
OneByteCPU
Location: Bracebridge, Canada in the deep woods of central Ontario
#4 Post by OneByteCPU » Wed Apr 13, 2022 9:01 pm
Have you checked for an aftermarket alternative?
Bill
____________________________________________________________
T61 - X201 - Edge 15 - T520 - X131e - X230 - T440 - X250 - T450 - T480
Users browsing this forum: No registered users and 105 guests
