T60p not charging showing 0% but Power Mgr says 'Good'
Just for kicks I reinstalled Win 7 on my T60p and after getting all updates etc, the battery now shows 0%, Power Manager says the battery is 'Good' and the orange light is blinking at a steady pace (not fast blinking) when laptop is 'charging' and the moment I pull the plug, the laptop shuts off right away. Needless to say the battery is not charging at all. Prior to the reinstall the OEM battery had a good 30-45 mins of life on Win 10
The laptop works perfectly fine otherwise. Not sure if part of the MB got cooked or is the battery dead? I have already tried the 30 sec reset that I read online but no luck there.
Any inputs?
Any inputs?
T400
T60p 2007-WUK
T60p 2007-WUK
Re: T60p not charging showing 0% but Power Mgr says 'Good'
Most likely the battery had died. How long did you let it try to charge?
Thanks. Overnight actually. I may end up buying the 'GreenCell' battery found on eBay.
T400
T60p 2007-WUK
T60p 2007-WUK
kfzhu1229
Use the power manager and read the voltage that's being read through the battery. If it is lower than like 9V most likely the battery is permenantly shot.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
T400
T60p 2007-WUK
T60p 2007-WUK
kfzhu1229
Assuming the voltage is correct this would be the voltage of a perfectly healthy battery pack.Think43p wrote: ↑Fri Apr 22, 2022 2:29 pmChecked. Voltage says 11.81v and design voltage says 10.80v.
https://imgur.com/a/j3fwChm
You might want to get another laptop, be it a 4:3 T61 with an already failed graphics, or the bare motherboard of any T6x, or something like that, to try to see if it would charge there.
If it charges fine there and not on your board, which I anticipate being more likely the possibility, then you might just have a blown battery fuse on the motherboard.
UXGA:
UXGA:
So turns out the battery had conked off. I bought a Green Cell battery and charges and works great.
https://imgur.com/a/WL1kFtp
T400
T60p 2007-WUK
T60p 2007-WUK
Have you installed IBM0068 Power Managment driver? Without it, power manager won't work as it should.
Daily driver: P50 6820HQ, M2000m, FHD IPS, 18/256GB
T601F T7800, NVS140M (03.07), UXGA BOE Hydis CCFL, 4/128GB, WiFi link 5300
Collection: T500, X41T, X60T, X61T, T60, T61 (4:3, 16:10), T61p, R500, X300, X301, X200, T42
Purchased another T410 power led but no post?
by TheMagicT410 » Fri Apr 03, 2026 6:57 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 462 Views
Last post by TheMagicT410
Why is my P1 Gen 7 so much better on battery? Cool, quiet, fast — but not on AC.
by Frippe » Tue Nov 18, 2025 5:21 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 3 Replies
- 9356 Views
Wed Nov 19, 2025 12:30 am
X220T Bios Update. USB listed after F12 but will not update.
by ThinkCat » Thu Nov 27, 2025 9:56 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 2 Replies
- 8979 Views
Last post by ThinkCat
Fri Nov 28, 2025 6:45 am
Battery use and charging etiquette for Classic ThinkPads?
by johnny1093 » Wed Oct 29, 2025 1:50 pm » in Thinkpad - General HARDWARE/SOFTWARE questions - 2 Replies
- 12581 Views
Last post by johnny1093
Sat Nov 01, 2025 8:46 pm
Users browsing this forum: No registered users and 86 guests
