Replacement sticky gunk for plastic screw covers?
solidpro
#1 Post by solidpro » Sun May 08, 2022 12:08 pm
Hi
I've been restoring some T2x machines and doing pretty well. As a result I've removed a huge number of those little black rectangles and circles which cover screws on the base and around the LCD panel.
They all use the same sort of gunky gooy sticky stuff, which is a bit old and worn out. Double sided tape would be too thick and superglue would make it impossible to remove and reuse in the future.
Does anyone know of a 'gunk' replacement for the backs of these which is super-thin, but not rock hard like superglue? I guess a bit like the glue they use on post-it notes.... enough to stick permanently but also reversible and thin.
Re: Replacement sticky gunk for plastic screw covers?
#2 Post by RealBlackStuff » Sun May 08, 2022 12:18 pm
I've been using Elmer's Rubber Cement for years.
It's perfect for those screw covers.
solidpro
#3 Post by solidpro » Mon May 09, 2022 4:16 am
Hi
Brilliant - thanks, I've ordered some Elmer's Rubber Cement and I'll give it a go later this week!
best
arpeas
#4 Post by arpeas » Thu Mar 27, 2025 12:21 pm
I'm interested in another solution for this, since the stuff RBS recommended is impossible to find in this part of the world. Anyone got something else?
ThinkPads are nice, y'know?
The collection: ThinkPad 310, A31, T40p, T43, T43p, T400, T510, T430
#5 Post by RealBlackStuff » Thu Mar 27, 2025 1:11 pm
I still have half a bottle of that Elmer's stuff, but it is gone a bit gooey after sitting here (in Ireland) for 5 years.
But check this out: https://www.hagglezon.com/en/s/Elmer's% ... r%20Cement
I also still have a load of (older model) new screw covers that I won't be using.
Users browsing this forum: No registered users and 49 guests
