thinkfan.conf for X301
Linux on ThinkPads
mikemex
#1 Post by mikemex » Tue Jun 14, 2022 12:45 am
Hi there,
I've been fiddling with thinkfan but I can't seem to get the /etc/thinkfan.conf file right in Ubuntu 22.04. Can you share a configuration file?
I believe T400 / X200 and other Montevina machines should have similar configurations.
Thanks.
humanplayer2
Re: thinkfan.conf for X301
#2 Post by humanplayer2 » Fri Nov 25, 2022 3:23 am
Not a direct answer, but I'm using zcfan on my X301. It allows minimal configuration, but so far, it's doing a good job.
It's available in the Ubuntu repos.
benlimanto
#3 Post by benlimanto » Tue Dec 13, 2022 10:22 pm
Hi there,
Thanks.
I've version 2.0 from the repo, the config is
# thinkfan Example Config File
# Please read the config manpage thinkfan.conf(5) before playing around with
# this.
# This is NOT a working config file that can just be copied. It is only meant
# to give a rough idea what can be done. In particular, don't copy & paste the
# fan speed config! Think about what you're doing.
# If you don't know what temperatures are right for your system, you should
# not be using thinkfan!
# Sensor Drivers and Temperature Inputs
# ATTENTION: The order in which sensors are specified here is significant when
# specifying the fan speeds further below!
# There are multiple ways in which a temperature input can be specified. An
# example for each is given below.
# The "correction:" and "optional:" keywords may be specified on any type of
# sensor.
sensors:
  # hwmon: Full path to a temperature file (single sensor).
  # Disadvantage is that the index in "hwmon0" depends on the load order of
  # the driver modules, which may change across bootups on some systems.
  #- hwmon: /sys/class/hwmon/hwmon0/temp1_input
   - hwmon: /sys/devices/platform/coretemp.0/hwmon/hwmon3/temp3_input
     max_errors: 10 # <<< New config option
   - hwmon: /sys/devices/platform/coretemp.0/hwmon/hwmon2/temp1_input
   - hwmon: /sys/devices/platform/coretemp.0/hwmon/hwmon1/temp2_input
  # hwmon: Base path with name-based search
  # Thinkfan will search under the given path for a hwmon driver that has a
  # file called "name" which contains the given name. This method should work
  # with all hwmon drivers and is robust against driver load order.
  # Sensors can also be optional, e.g. in case of removable hardware
  # atasmart: Read the temperature from a hard disk via S.M.A.R.T
  # Note that this is unreasonably CPU-intensive. Since Linux 5.6, the kernel
  # can report the temperatures of hard disks via the hwmon interface (see the
  # example above), which should be preferred if available.
  # This is only available if thinkfan was compiled with USE_ATASMART enabled.
  #- atasmart: /dev/sda
  # tpacpi: Legacy interface to the thinkpad_acpi driver
  # Particularly on older Thinkpad laptops, this interface may give access to
  # 8-16 temperature sensors, but it may be hard to tell where/what exactly
  # they measure.
  # Some documentation for older models may be found at the thinkpad wiki:
  # https://www.thinkwiki.org/wiki/Thermal_Sensors
  # Note that the hwmon interface is to be preferred nowadays.
  # - tpacpi: /proc/acpi/ibm/thermal
  #   # Some of the temperature entries in /proc/acpi/ibm/thermal may be
  #   # irrelevant or unused, so individual ones can be selected:
  #   indices: [1, 2, 3, 4]
  # nvml: The proprietary nVidia driver
  # Temperatures can be read directly from nVidia GPUs that run with the
  # proprietary driver. The "nvml:" entry must specify the PCI bus ID of the
  # GPU (can be found with lspci)
  # Note that this does not work with the open-source "nouveau" driver. Open
  # source drivers should support the hwmon interface instead (see above).
  # - nvml: 27:00.0
# Fan Drivers
# Currently, thinkfan supports only one fan, but support for multiple fans is
# in development and will be released soon. For the time being, the examples
# given below are mutually exclusive.
fans:
  # hwmon: Full path to a PWM file
  # Also subject to the potential problem with driver load order (see above)
  #- hwmon: /sys/class/hwmon/hwmon0/pwm1
  # hwmon: Path to a complete driver folder
  #- hwmon: /sys/class/graphics/fb0/device/hwmon
  #  indices: [1] # Use pwm1
  # - hwmon: /sys/class/hwmon
  #   name: amdgpu
  #   indices: [1]
  # tpacpi: Thinkpad-specific fan interface
  # Currently, this is the only way to use disengaged and automatic mode on
  # thinkpads.
  - tpacpi: /proc/acpi/ibm/fan
# Fan Speeds (detailed mode)
# It is generally advisable to configure the temperature limits for each
# sensor individually.
# The speed values used here range from 0 to 255, which is valid for the PWM
# control files used by hwmon-based drivers.
# The temperatures specified in upper_limit and lower_limit apply to the
# sensors in the same order in which they were specified in the "sensors:"
# section above, and their length must match the total number of sensors that
# have been configured.
levels:
  - speed: 0
    upper_limit: [38, 38, 38]
  - speed: 1
    lower_limit: [38, 38, 38]
    upper_limit: [41, 41, 41]
  - speed: 2
    lower_limit: [41, 41, 41]
    upper_limit: [43, 43, 43]
  - speed: 3
    lower_limit: [43, 43, 43]
    upper_limit: [45, 45, 45]
  - speed: 4
    lower_limit: [45, 45, 45]
    upper_limit: [47, 47, 47]
  - speed: 5
    lower_limit: [47, 47, 47]
    upper_limit: [50, 50, 50]
  - speed: 6
    lower_limit: [50, 50, 50]
    upper_limit: [53, 53, 53]
  - speed: 7
    lower_limit: [53, 53, 53]
    upper_limit: [57, 57, 57]
  - speed: 64
    lower_limit: [57, 57, 57]
I'm in fedora, but the config should work I think, for speed 64, you need to run thinkfan with -D flags, if not well, you can remove the speed 64.
It will cause the service fail to run if you force the 64/max speed without -D flag.
X220 with Win 10 21H2 Fedora 38 XFCE 4.18 (official spins)
i7-2640m, disabled Hyper Thread, Temp Drop on average 10*C, all core activated, need KVM for Windows
12gb RAM (enough for now, DDR3L)
480 Kingston Fake SSD
64gb Samsung SD Card
Recently rolled back to Windows 7 from Win 10 21H2. Sad
Return to “Linux Questions”
