X220/X230 FHD replacement display cable
Old(er) Thinkpads with New(er) Intestines: X62/T50/T70/X210/X330 etc.
X330i7
#1 Post by X330i7 » Tue Jun 14, 2022 4:22 am
Hi guys
I've not been able to find anywhere for sale online a replacement display cable for a X230 modded with FHD. Like this: https://nitrocaster.me/store/x220-x230-fhd-mod-kit.html
I bought a LCD Display cable by mistake and decided to keep it for reference. The connector in circle is the one i'm after and the other end must be compatible with the sharp LQ133M1JW monitor model versions
Could someone help point to where i can have better chance of finding this unrepresented product online?
Thanks :thumbs-UP:
theterminator93
Re: X220/X230 FHD replacement display cable
#2 Post by theterminator93 » Tue Jun 14, 2022 7:24 am
It's been a few years since I did the FHD mod on my X220 but as far as I know you should be able to use a standard eDP cable. Just match the length and connector orientation and you should be good to go. IIRC it's a 2 lane interface but based on the pic it's 40 pins.
The recovery sets guy
exander
#3 Post by exander » Tue Jul 05, 2022 8:59 pm
Hi guys
Thanks :thumbs-UP:
I think I may have one somewhere here (EU-CZ) if you need it.
Return to “51nb and other modded Thinkpads”
