Wondering about the expressCard slot.
cultOfThinkpad
#1 Post by cultOfThinkpad » Wed Aug 10, 2022 1:12 am
I'm rather interested in the expressCard slot which I removed from my W500.
I took it off to harden my system, so that attackers can't somehow compromise it through this slot
but, lately, I was interested in buying a USB extension card for it and simply epoxying it to the slot
so nobody can remove it.
Who knows if I need more USB ports?
So I just have a couple of questions.
Image Image Image
I know there are two types of expressCard slots which are expressCard/54 and /34.
Well, mine seems to have two very slim slots. The top one has a wedge whereas the bottom one doesn't.
What can anyone tell me about this?
Thanks.
Re: Wondering about the expressCard slot.
#2 Post by dr_st » Wed Aug 10, 2022 8:03 am
One of them (I believe it is the top one when installed in laptop) is ExpressCard (PCI-Express x1), the other one is CardBus/PC Card (PCI 32-bit).
cultOfThinkpad
#3 Post by cultOfThinkpad » Thu Aug 11, 2022 1:58 am
I see. Well, I'm looking to use OpenBSD as my daily driver.
I took a look at a good USB 3.0 extension card but learned that BSD doesn't support it.
Any other ideas for what kinda devices to use in these slots or is expressCard just bust?
#4 Post by axur-delmeria » Thu Aug 11, 2022 3:12 am
unixed
#5 Post by unixed » Fri Aug 12, 2022 5:48 pm
You can put a USB 2.0 expresscard adapter in it. It will work with BSD. The USB ports on your W500 are flaky and liable to break just with regular usage.
cultOfThinkpad
#6 Post by cultOfThinkpad » Tue Apr 02, 2024 8:27 am
Hi. It's been a long time since I started this thread.
So I've been looking up Cardbus devices and, if anyone's correct that I can only fit an ExpressCard and CardBus device (not two ExpressCard ones), I'm thinking of using a USB 2.0 CardBus card and a ThinkMods ExpressCard-to-NVMe adapter.
But I realize the devices for either slots tend to have these huge bulging ends that stick out of the slots where you can plug your peripherals in. Would my proposed set up be feasible? Anyone ever tried?
cultOfThinkpad
#7 Post by cultOfThinkpad » Tue Apr 02, 2024 8:29 am
Actually, while we're at it, I also notice that some ExpressCard and CardBus devices come with driver CDs for Windows.
Will they work with Linux straight out of the box without the need to install any drivers?
#8 Post by axur-delmeria » Tue Apr 02, 2024 9:43 am
With regards to Linux support in general (not restricted to Cardbus and/or Expresscard):
If you're lucky, the device is supported by the Linux kernel without needing to do anything.
Some have drivers in the kernel, but require firmware files to be loaded. Most mainstream Linux distributions include them in the default install, so it's becoming less of an issue.
If luck isn't on your side, you'll have to compile the driver yourself. Sometimes, it's just a matter of installing a package (the package manager does the heavy lifting). Worse case if you have to actually search for it all over the net. :(
The absolute worst case is that some devices don't have Linux drivers at all. :cry:
For Expresscard USB 3.0 adapters, the AFAIK the kernel has them.
Cardbus WiFi esp. the older ones are hit-or-miss.
Tinstaafl
#9 Post by Tinstaafl » Fri Jun 21, 2024 5:07 am
I have a W500 and run Kanotix Linux (a Debian derived distro) on it. I put a USB3 adapter in the ExpressCard slot. The adapter sits flush with the case & seems to work just fine. Haven't done any testing for speed but I like having the extra USB ports. Parked in its dock I have 9(!) USB ports available (although I think one of the laptop's built in ports is getting flaky).
Love having available all the various other built in ports, card reader, DVD writer, matte WUXGA, touchpad buttons etc. instead of needing external dongles. I maxed out its RAM and installed an SSD. Made a huge difference. But it's starting to struggle on websites. If only there was a motherboard upgrade available. Even as a Frankenpad. I've had this one for 14 years and am having trouble finding a modern day equivalent.
rumbero
#10 Post by rumbero » Fri Jun 21, 2024 8:10 am
[...] I'm thinking of using a USB 2.0 CardBus card and a ThinkMods ExpressCard-to-NVMe adapter.
Unless the developer behind that famous ThinkMods store has (at long last) finally reappeared, than better forget about that ExpressCard-to-NVMe adapter.
It looked like a great and potentially successful product but it wasn't destined to ever become reality. The last updates on https://thinkmods.store/blogs/news are from 2021 and the associated discord channel was full of complaints by disappointed people last i looked a year ago. This guy was all promises for delivery of the goods but unfortunately simply disappeared after a long history of excuses and unfulfilled promises.
A pity though, this had all characteristics of something well done. At least there are some cheap NVMe expresscard adapters to be had from elsewhere (aliexpress et al) which are reported (by others) to work sufficiently well.
While we are at it:
Still occasionally use my good old T60/61 Frankenpads with an Adaptec SlimSCSI 1480B Cardbus adapter to access old UltraSCSI periphery of mine (HP Scanjet 4C, some MO drives and also rescuing hard disk contents using a BlueSCSI-v2).
That old Frankenpad still serves its purpose.
TPFanatic
#11 Post by TPFanatic » Fri Jun 21, 2024 8:37 am
for $25 or so you can get on aliexpress or ebay an expresscard to internal m-key NVME adapter, I own one myself, it works well. 2230 and 2242 fit inside it, there's a hole so longer cards can plug in but will stick out.
for example: https://www.aliexpress.us/item/3256805422248267.html
unixed
#12 Post by unixed » Mon Jul 01, 2024 1:27 pm
You can effectively do the same thing as the thinkmods adapter. Use either a USB2 mPCIe adapter or a cardbus USB adapter then run a bootloader on there that will boot from something in the expresscard slot, whether it be an NVMe or USB3 drive via an adapter.
I usually use a flush dual USB2 expresscard adapter since the thinkpad USB ports are notoriously prone to breaking on this generation. You can boot from it.
TPFanatic
#13 Post by TPFanatic » Mon Jul 01, 2024 4:29 pm
Make sure your bootloader will see the nvme device. I couldn’t get clover to recognize the nvme plugged into to wwan slot on my t500, no clue what i missed… a windows installer booted from the clover would see the nvme tho, but clover couldn’t restart to that nvme.
Users browsing this forum: No registered users and 48 guests
