OSD not working on T60p
T60/T61 Series
ibrazhko
#1 Post by ibrazhko » Fri Sep 02, 2022 5:36 pm
I have performed clean Windows 7 install on my T60p. I then installed all Windows updates and drivers (as downloaded from Lenovo EOL support page), and everything works fine except for the on screen display (OSD). No matter what I do, it just doesn't work! This is very frustrating.
As far as I know, the problem is most likely is in the realm of one of the three drivers: Power Manager Driver, Hotkey Features Integration, and Lenovo System Interface Driver. I've tried a few different versions, but nothing helps. Could please anyone with Windows 7 on their T60(p)/T61(P)/T400/etc advise which version of those three drivers mentioned above you're using to get the OSD to work?
Would be very helpful, because this problem is driving me nuts!
ibrazhko
Re: OSD not working on T60p
#2 Post by ibrazhko » Sat Sep 03, 2022 3:56 am
Okay, I was finally able to solve this by installing Microsoft Visual C++ 2010 Redistributable package. File name is vcredist_x86.exe
Users browsing this forum: No registered users and 55 guests
