T61 with brand new battery that died in a few months.
devinfriday
Hi, i have putted together a T61 with a T9300 and 8Gb of DDR2 ram with a brand new compatible battery. This battery died a few months after first turn on, if unplugged from AC it did not power on and if it's on AC the notebook insta-turn off if disconnected from the wall outlet. The weird thing is HWMonitor reports 0% wear level and 103% of capacity, the same with BatteryInfoView. What has gone wrong with it?
Is the battery simple a piece of crap?
devinfriday
Re: T61 with brand new battery that died in a few months.
After a few tests i found that the battery is good, i have a spare one with less than 10% of charge that is reported as is from batteryinfoview, so this software is ok, it's the T61's fault, it won't power on only with battery, if i power on AC it starts, but if the AC fails the notebook insta-power off. Maybe some fuse blow up
devinfriday
devinfriday
Anyone has some advice to give?
TBH it's hard to say whether the issue is the laptop or the battery.
If you had another unit to test the battery on, it would be easier to narrow down the issue.
Hi, you may have a faulty fuse, in your case it could be F12.
T400 6473-PVU | T43 2686-DHU | 560 2640-20U
devinfriday
I have two T61s but different MTM so they are not compatible. Battery info reports that the battery is good.axur-delmeria wrote:TBH it's hard to say whether the issue is the laptop or the battery.
devinfriday
Interesting, can you tell me if it is repairable or not?JaroTech wrote:Hi, you may have a faulty fuse, in your case it could be F12.
To check if the fuse is good, it involves measuring the fuse resistance or the voltage on its terminals. To do this, you need a multimeter and know how to use it.
devinfriday
I have found a buyer for the T61, thanks anyway.JaroTech wrote:To check if the fuse is good, it involves measuring the fuse resistance or the voltage on its terminals. To do this, you need a multimeter and know how to use it.
T480 screen shuts off after a few seconds to a minute after starting to use it.
by FranklinHawkings » Wed Oct 22, 2025 5:26 pm » in ThinkPad T430-T495 / T530-T590 Series - 13 Replies
- 29592 Views
Sat Nov 01, 2025 12:09 am
FS: NOS Frankenpad T61p motherboard 44c3926 NEW 2011 date NVIDIA fx570m fits 14.1 and 15 4:3 t60, t61
by andre#4 » Fri Feb 06, 2026 1:58 pm » in Marketplace - Forum Members only - 1 Replies
- 3973 Views
Last post by andre#4
Mon Feb 09, 2026 9:34 pm
[WTB] Thinkpad x61 battery (battery life doesn't matter as long as it works)
by Redaa » Sun Jan 25, 2026 6:08 am » in Marketplace - Forum Members only - 2 Replies
- 6038 Views
Last post by Redaa
Sun Jan 25, 2026 6:27 am
TrackPoint and Bluetooth problems on T61
by giovanazzi » Mon Nov 03, 2025 7:43 am » in ThinkPad T60/T61 Series - 2 Replies
- 11615 Views
Last post by giovanazzi
Mon Nov 03, 2025 10:37 am
Users browsing this forum: No registered users and 125 guests
