- 15-16” screen size
- 32gb RAM
- Touchscreen
- Numeric Keypad
- Consider used / refurbished to keep cost down
Thanks for your reply Zaz. T-15/16 is where my thoughts are currently and they could be within budget of say £1-1.5k. Does it matter which gen of either the above models to have the touchscreen option? Any recommendations for places to purchase reliable 2nd hand models?ZaZ wrote: ↑Tue Nov 22, 2022 10:16 amWhat are you looking to spend and how much oomph do you need? A T15 or T16 series looks like a good bet. A newer version will get you a faster CPU and likely a better screen, but an older version will save you some cash and still be useful unless you need top performance. Seems kind of like a value judgment. I personally wouldn't go below a T580, which will come with a low watt quad core that will offer you much better performance than its dual core brethren, but your money, your call. Good luck my friend and welcome.
Users browsing this forum: No registered users and 44 guests
