T61 (large version) power button stuck
T60/T61 Series
fiat682
#1 Post by fiat682 » Wed Dec 28, 2022 3:06 pm
Hi after sitting for months this Thinkpad when plugging it in basically turned on immediately then posts and dies, i unplugged things and i found that unplugging the keyboard it stays on, the power button itself is not stuck as it presses normallybut the contacts appear to be
Is it fixable or is it not related to the keyboard? I've thinking about putting it in the dishwasher to see if anything changes
Lenovo x220i t w7pro
IBM Thinkpad T30 p4 1gb XPpro
IBM Thinkpad T22 BOD (looking for repair)
Lenovo T61 w7
[Restored] Lenovo sl500 win vista
theterminator93
Re: T61 (large version) power button stuck
#2 Post by theterminator93 » Thu Dec 29, 2022 1:25 pm
The small switch under the button may have fractured and is shorting out. It's probably best to just source a new keyboard, but if you feel inclined to you may be able to try to disassemble and replace the switch (if you can find a suitable replacement that will fit).
The recovery sets guy
fiat682
#3 Post by fiat682 » Mon Feb 06, 2023 8:08 am
No idea how i could replace it so can I go sure with a used kb?
Lenovo T61 w7
theterminator93
#4 Post by theterminator93 » Mon Feb 06, 2023 8:36 am
That's what I would do. They are inexpensive enough. All T60/T61 keyboards are interchangeable. T400/T500 work as well but are a little flimsier, which some might notice.
Users browsing this forum: No registered users and 109 guests
