Suddenly the laptop just wouldn’t turn on most of the times I press the power button. On the times it did turn on, only twice did I get a “0187 EAIA data access error” and a “2200: Mahine Type and Serial Number are invalid.” Those errors have not appeared since
Turning on the laptop, the system clock would be out of sync. A windows update and replacement of the back up battery seemed to have resolved this. However, the original issue still persists. It only turns on occasionally when the power button is pressed.
I’ve tried doing a power reset but to no avail. Turning it on without the battery and only the charger, I just get three rapid blinks from the battery light indicator. Turning it on with the battery and charger, I get three short blinks, one long blink, then a short blink on the battery light indicator. Would this be an issue with the motherboard or EEPROM?
Extra info: No major upgrades or modifications have ever been done on the laptop save for upgrading to an SSD and adding one more stick of RAM. I've already tried reseating the RAM, and booting the machine using only one of the RAM slots at a time but still no luck
Thinkpad T420 suddenly won't turn on. Only turns on occasionally
Re: Thinkpad T420 suddenly won't turn on. Only turns on occasionally
sometimes this erratic behavior is caused by humidity - once i restored another thinkpad with such issues by removing the kb and putting it in the oven at 50 celcius
you have to keep it in a plastic bag if you don't use it often
T500 - T9600, 8g ram, 1680x1050
T420 - 2450M, 16g ram, 1366x768
X61t - L7500, 4g ram, 1024x768
W520 - 2760QM, 16g ram, 1920x1080
X201 - 560M, 8g ram, 1280x800
Thinkpad T60 won't turn on
by cynthiacarmichael » Thu Mar 26, 2026 4:40 am » in ThinkPad T60/T61 Series - 1 Replies
- 836 Views
Last post by Glaurung-quena
Thu Mar 26, 2026 9:34 am
T470s won't allow me to login into Linux -- only UEFI, boot screens and tty interfaces seem to work
by irock » Wed Mar 18, 2026 3:34 pm » in ThinkPad T430-T495 / T530-T590 Series - 4 Replies
- 3308 Views
Last post by farmall
Fri Mar 27, 2026 2:26 pm
T470S suddenly stopped booting. Screen keeps black while everything else seems to work
by irock » Sat Feb 28, 2026 2:34 pm » in ThinkPad T430-T495 / T530-T590 Series - 9 Replies
- 6193 Views
Last post by irock
Mon Mar 16, 2026 12:57 pm
SOLD: thinkpad X61, T8300, 8GB. SSD, Atheros AR938 - EU ONLY
by zz7 » Wed Oct 29, 2025 10:57 am » in Marketplace - Forum Members only - 0 Replies
- 7333 Views
Last post by zz7
Users browsing this forum: No registered users and 76 guests
