Hi
After some problems with a gen 1 Trackoint and mouse buttons I am now in the lookout for another 2nd hand P1.
Are there any known issues of any kind I should be aware across the generations?
Any good summaries of tests or long term reviews or similar out there of the gen 1 throught 5 that can help me with eliminating any problems or choose other than the public specifications.
P1 Gen1-5 Pro's and Con's
H-Atkinson
Re: P1 Gen1-5 Pro's and Con's
P1 Gen1 and Gen2 are very similar, basically a spec bump on the same chassis for the gen2, both are solid, not very different functionally now that theyre both almost 5 years old
Gen3 gets a new chassis (lose the ethernet dongle port) and a minor spec bump along with marginally better cooling, as well as a bigger battery
Gen4 gets another new chassis, much improved cooling (breathe through keyboard), 16:10, and a meaningful spec bump, but the keyboard drops to 1.5mm of travel from 1.8
Gen5 is a spec bump with a new cooler (vapor chamber) for the big-die GPUs, otherwise the same as gen4 with some new screens
P1 Gen 5
P52
T25 Anniversary
Many more as well!
P52
T25 Anniversary
Many more as well!
Thanks for the short and spesific summary, appreciated.
As expected the next is an upgrade without any major concerns.
- 5 Replies
- 12078 Views
Last post by Python.p
Mon Oct 27, 2025 3:57 am
P15 gen1 ... will a 1TB + 4TB NVMe SSD pairing work?
by portsample » Thu Nov 27, 2025 8:23 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 7880 Views
Last post by portsample
Thu Nov 27, 2025 10:00 pm
Thinkpad p14s gen1 (Intel version) WWAN module
by EarthNature » Thu Feb 19, 2026 5:32 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 0 Replies
- 2561 Views
Last post by EarthNature
Lenovo Thinkpad L16 AMD Ryzen 7 PRO 250, UEFI and SMTP
by jgpallero » Fri Dec 05, 2025 5:23 am » in Thinkpad AMD-Ryzen - 1 Replies
- 7740 Views
Last post by Ibthink
Tue Jan 27, 2026 5:58 pm
