Hi, guys!
I have x330 and 2k mod.
Here is my screen and cable (AUO B133QAN02.0)
I dont know how much pins eDP connector (looks like 40)
https://ibb.co/jTFTN1J
https://ibb.co/GVcCHzJ
and have two questions:
1. Is it possible to replace 2k with 1080p on this motheboard? (HiDPI support is not good in Linux)
2. Can anybody help me to find same eDP cable for this screen or alternative for 1080p ?
Thanks.
Need help! x330 edp cable is broken, cant find same
Re: Need help! x330 edp cable is broken, cant find same
2k panels use 40 pins. You are right 1080 would use a 30 pin cable. You can probably find something comparable on aliexpress.
If your current LCD is 2560x1600, that is 16:10 resolution and I would suggest that you look for a 1920x1200 in 13.3" so it fits your modified lid correctly. 1080 is 16:9 and won't fit right.
sent from my iPhone
maybe its 0.4 Pitch 40 Pin 20729 (B133QAN02.0) to 20682-040E-02 if i understand correctly
but its impossible and hard to find (taobao/alibaba/aliexpress)
just bought this
https://aliexpress.ru/item/1005004399540653.html
but another side of cable have a 0.5 Pitch FPC 40 Pin.
so i need adapter which connect it with motherboard.
only hope that Xue will back
just bought this
- 1 Replies
- 157 Views
Thu Apr 23, 2026 12:30 am
Trying to find 14" LCD cable for T60
by Glaurung-quena » Sun Dec 07, 2025 8:32 am » in ThinkPad T60/T61 Series - 2 Replies
- 5449 Views
Last post by Glaurung-quena
Tue Dec 09, 2025 7:38 am
- 10 Replies
- 10171 Views
Sun Dec 21, 2025 4:38 pm
T23 - CRC1 0175 - Where to find BIOS update?
by DarkSamus9000 » Mon Jan 05, 2026 8:41 pm » in ThinkPad T20-T23 & T30 Series. NOT for T25-Retro - 17 Replies
- 13609 Views
Last post by DarkSamus9000
Mon Feb 16, 2026 9:52 pm
