(Breaking out to differentiate from EC thread, as it really doesn't have much to do with it - apologies for shuffling content around)
Has anyone successfully applied all the power saving tricks that worked for the X210 to the X2100? I haven't been able to get the power consumption under 7W at idle, no matter what. I added the 8186 driver, patched i915 (confirmed I get PSR enabled) and the previously mentioned kernel command line parameters but none of it seems to get any lower than those 7W.
Thoughts / successes on this topic?
R
X2100 power optimizations?
flyingfishfinger
Re: X2100 power optimizations?
Which screen are you using?
As far as I understand, 12.2" FHD and the original 12.1" do not support PSR even if it is enabled on the chipset / kernel level.
flyingfishfinger
Digging this up again... I never made more progress here (didn't spend more time), but to answer the above question I'm using the 3000x2000 screen, or at least that's the target. I do also have have the 2880x1920 but that was never installed on the X2100, so I can't say whether the differences are due to the screen or not...
I'd still like to get to the bottom of this, but I'm out of ideas :/
R
R
I can't break 11W idle with mine, and the PCIe slot won't go above x1 without spewing AER corrections everywhere. So I'm here just kinda subscribing I guess.
T450 Will Not Power Up
by shajoe44 » Mon Nov 10, 2025 8:23 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 4724 Views
Last post by quietude38
Fri Jan 23, 2026 11:37 am
T480 won't boot - power button just flashes.
by kae2020 » Fri Dec 05, 2025 11:20 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 11820 Views
Last post by kae2020
Sun Dec 07, 2025 2:03 pm
- 11405 Views
Last post by dcfbf
Wed Jan 21, 2026 2:32 pm
- 1 Replies
- 1133 Views
Sun Mar 08, 2026 5:27 pm
