IBM T42 / MCP2 4.52 - USB drivers
OS/2 on ThinkPads
ColinH
#1 Post by ColinH » Thu Feb 23, 2023 7:31 am
MCP2 installed easily from the CDs after I deleted all existing partitions and created a 16Meg partition on my T42.
I've got drivers for everything successfully working with the exception of USB.
Does anyone have the definitive USB driver set for USB and can provide the correct CONFIG.SYS statements please?
Are there any BIOS settings I need to be aware of?
Thanks.
Colin.
dryeo
Re: IBM T42 / MCP2 4.52 - USB drivers
#2 Post by dryeo » Mon Mar 06, 2023 11:41 pm
Probably https://hobbes.nmsu.edu/download/pub/os ... drv247.zip is the best current free stack. Forget if you need Warpin to install, look in the same place for warpin. It will tell you of config.sys changes or do it itself if a warpin package.
matti157
#3 Post by matti157 » Mon Mar 24, 2025 4:44 pm
What procedure did you follow to install OS/2 on the T42? What iso did you use?
Return to “OS/2 Questions”
