I own 2 great Thinkpads; X13 gen 1 AMD ryzen 7 4750u, 32gb ram, touchscreen display 300nits 45% ntsc and an T14s with Intel 10210u, 8gb, low power display 400nits 72% ntsc.
As you probably know both machines share the same mobo design. This give me the idea to create 2 Frankepads and swap theirs motherboards. Due to the fact that T14s have better larger display 400nits, bigger battery 57wh, better keyboard and so I decided to make Frankepad T14s with ryzen 4750u and 32gb ram my primary machine.
So the process it’s not so difficult; In order to begin disconnect the battery, disconnect all cables (make sure you make some photos before), remove all screws and put them in order, and then carefully remove the mobo.
Keep in mind that there some minor differences between those machines despite same mobo design; the coolers are design different and usb cable are not the same.
The major concern was the cooler compatibility but luckily the switch works like a charm; tested the temps in some stress test and everything was under 80 degrees not throttling on both machines. The only problem is that the usb cable for the right usb extension was too short when swapping from x13 on t14s because it have larger chassis.
However everything works perfectly: displays and touch, camera, keyboard, touchpad, touch sensor, battery compatibility.
Hope this information was helpful for anyone who’s planning to swap the motherboards between Thinkpad X13 and Thinkpad T14s both gen 1.
https://i.imgur.com/z70PREQ.jpg
https://i.imgur.com/p53xt9b.jpg
https://i.imgur.com/n5aDLai.jpg
https://i.imgur.com/pq37dDz.jpg
Successfully switch motherbord from Thinkpad X13 to T14s
dragosxpan
- 0 Replies
- 3603 Views
Last post by Caspian26
Sat Jan 31, 2026 12:12 pm
- 2 Replies
- 8416 Views
Last post by LayaVulpes
Tue Oct 21, 2025 12:12 pm
Thinkpad 380XD bizarre power failure
by PhaseSeeker » Mon Oct 20, 2025 10:30 am » in ThinkPad Legacy Hardware - 2 Replies
- 6829 Views
Last post by PhaseSeeker
Tue Oct 21, 2025 5:47 am
Retro ThinkPad Battery Repairment
by Jifeng Chen » Mon Oct 20, 2025 10:36 pm » in ThinkPad Legacy Hardware - 7 Replies
- 7107 Views
Last post by Jifeng Chen
Wed Oct 22, 2025 6:08 pm
