Changing LCD panel on W530
Prickleyebush
My W530 died suddenly and was completely unresponsive to all the usual tests so I asked a local repairer for a diagnosis and he decided it was a motherboard fault and beyond economic repair. I've bought a cheap replacement which lacked a battery and charger and that works fine. I've swapped my old hard drive so I now hav an SSD and also the keyboard so I have a backlit version now. Everything good so far. The next upgrade I'd like to try is to use the 1600x900 display from my old machine and fit it to the replacement one which only has a 1366x768 resolution panel (both 15.6 displays). This is a bit trickier for someone like me with limited experience so I'd like to know beforehand that it should work. Any advice gratefully received please.
Re: Changing LCD panel on W530
Get the illustrated W530 manual from the HMM link at the top of this page.
Prickleyebush
Thanks, I have the manual and I'm sure I can change the panel but I just wondered whether there was anything that might stop the higher resolution panel working beforehand.
Just make sure you remove battery and AC then press the power button a few times to drain the capacitors before unplugging the LCD and/or cable, to prevent any blowing of the backlight fuse.
My understanding is all T/W520,530 can be upgraded from WXGA to the HD+ or FHD panels with no other change in parts. Personally I have done this on a T520 with no problem.
You have the option of swapping your entire lid assemblies or extricating and transplanting just the LCD. I think the latter is easier, the front bezel is easier to remove than the upper palmrest, then it's just taking the hinge rails out of the lid to remove the LCD from them. You only have to be careful removing the lid sensor from the left hinge, it's stuck on pretty good from the factory.
sent from my iPhone
Prickleyebush
Thanks, that's really useful. I've been careful to follow your advice and successfully removed the LCD panel from the non-working machine. Tomorrow I'll try swapping the panels. I'll post again with the results.TPFanatic wrote: ↑Mon Apr 17, 2023 1:54 pmJust make sure you remove battery and AC then press the power button a few times to drain the capacitors before unplugging the LCD and/or cable, to prevent any blowing of the backlight fuse.
T530 Screen Upgrade to FHD Panel - Which Panel?
by Silverlake » Wed Dec 17, 2025 3:39 pm » in ThinkPad T430-T495 / T530-T590 Series - 0 Replies
- 8721 Views
Last post by Silverlake
WTB: 600E Replacement LCD panel & ribbon (UK)
by MDBenson » Wed Mar 04, 2026 6:14 am » in Marketplace - Forum Members only - 0 Replies
- 1680 Views
Last post by MDBenson
W530 motherboard in W520 chassis?
by alalalalysa » Fri Nov 21, 2025 5:16 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 2 Replies
- 9043 Views
Last post by dcfbf
Fri Nov 21, 2025 11:30 am
W530 color sensor issues
by astral » Tue Mar 31, 2026 4:23 pm » in ThinkPad W530/W540/W541/W550 Series - 4 Replies
- 2036 Views
Last post by astral
Sat Apr 18, 2026 7:54 pm
Users browsing this forum: No registered users and 44 guests
