I've tried holding down the power button for a really long time, pressing/holding the normal reset button, and even the motherboard battery reset button. No change. I also tried pulling the SSD to see if perhaps it was halting the post process, but the condition persisted. In my research, there have been a handful of reports of this, but no solid solutions. Has anyone here seen that before? If so, is there some kind of secret backdoor key combo or a way to reinstall the motherboard firmware off of a flash drive when the computer is in this state? I've installed motherboard firmware quite a few times in my life, but never once had it end this way. I was expecting the ThinkPad X1 to be less of a sissy than this
Second-generation Carbon no-boot after firmware update
SurrealMustard
I'm dealing with a second-generation X1 Carbon, (20A8) fresh off the eBay boat. Loaded up Windows, installed Lenovo System Update, and let it (and Windows) begin the process of installing drivers and patches. After reaching the home stretch, I opted to install the newest version of the motherboard firmware. This went well, or so I thought. After successfully staging, the machine rebooted, finished flashing, and then restarted once more... to nothingness. It now powers on, blinks the shift key light as it normally would, lights up the touch buttons, but I get nothing on screen at all whatsoever. If I leave it for a minute or two, it eventually shuts off on its own. Otherwise, it only requires a brief press of the power button to accomplish this.
Re: Second-generation Carbon no-boot after firmware update
Problems like this generally require a hardware SPI flasher like the CH341A, a SOIC8 clip, and another computer. That said, I've never done any sort of hardware flashing so I can't be of much help in that regard.
$hafted by Micro$haft, so what's new?
If/when you go for CH341A, get a black one with 3.3V option built-in.
X220T Bios Update. USB listed after F12 but will not update.
by ThinkCat » Thu Nov 27, 2025 9:56 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 2 Replies
- 8977 Views
Last post by ThinkCat
Fri Nov 28, 2025 6:45 am
T480 screen shuts off after a few seconds to a minute after starting to use it.
by FranklinHawkings » Wed Oct 22, 2025 5:26 pm » in ThinkPad T430-T495 / T530-T590 Series - 13 Replies
- 23627 Views
Sat Nov 01, 2025 12:09 am
X1 tablet gen 3 won't boot after SSD replacement
by babblefish » Thu Feb 19, 2026 10:22 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 7 Replies
- 3782 Views
Last post by babblefish
Fri Feb 20, 2026 7:44 am
W520 doesn't boot after critical battery error...
by salzrat » Mon Mar 16, 2026 12:18 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 12 Replies
- 3664 Views
Fri Mar 20, 2026 1:32 pm
