I decided to go ahead with the motherboard replacement on my T520.
I saw something in the manual about resetting the serial number. How important is that?
Same thought about the OEM Windows 7 and 10. It will look to MS like I have a new machine (or the one the MB came from. Do I need to do anything to correct that?
Resetting Serial number after motherboard (or BIOS) change
Re: Resetting Serial number after motherboard (or BIOS) change
My expectation is Microsoft will reactivate you with the phone service and/or the windows 7 key on the bottom of the laptop. I would try to activate first and see what happens.
sent from my iPhone
You can change the TYpe, S/N and others using this HMD program: https://download.lenovo.com/ibmdl/pub/p ... tm38us.exe
When you run this first time, it unpacks into a folder.
In that folder you find installing information.txt for making a self-booting USB-stick with which you can run most Thinkpads, incl. the T520.
With that you can then change the BIOS data back to the 'old' mobo info (if you made a note of that, or from the label on the laptop bottom.)
I think I posted this elsewhere, but in the end all I had to do was as you suggested - Just entered the key. This worked, I believe because I had W10 activated on my MS account. This with my existing W10 - no need to re-install. I didn't change the model/SN in BIOS, but Windows picked the new ones up in activation process.
I am almost back to square one
t440p: I can't change settings in BIOS
by unirill » Sat Jan 17, 2026 12:13 pm » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 5284 Views
Last post by dcfbf
Wed Jan 21, 2026 11:27 am
T480 screen shuts off after a few seconds to a minute after starting to use it.
by FranklinHawkings » Wed Oct 22, 2025 5:26 pm » in ThinkPad T430-T495 / T530-T590 Series - 13 Replies
- 29768 Views
Sat Nov 01, 2025 12:09 am
FS: BIOS locked Thinkpad T60 motherboard, free for the cost of postage
by Glaurung-quena » Sun Feb 22, 2026 7:03 am » in Marketplace - Forum Members only - 0 Replies
- 2466 Views
Last post by Glaurung-quena
X220T Bios Update. USB listed after F12 but will not update.
by ThinkCat » Thu Nov 27, 2025 9:56 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 2 Replies
- 10284 Views
Last post by ThinkCat
Fri Nov 28, 2025 6:45 am
Users browsing this forum: No registered users and 66 guests
