X230T touch screen not working
X230-X280, X390 Series
greeyak
#1 Post by greeyak » Fri Aug 11, 2023 2:33 pm
Hi all,
I bought a used ThinkPad X230T running on Windows 10, and as I was not familiar with tablet laptops prior to this, I didn't think to test all features before buying. Basically, everything works right except for the touch screen. I couldn't test it right away as the guy didn't have the pen to go with the laptop, I had to buy one separately.
Device manager doesn't recognize it at all and no drivers I found online fix the problem either. Are there any other fixes I should try before deciding it's a hardware issue?
ZaZ
Moderator
Moderator
Re: X230T touch screen not working
#2 Post by ZaZ » Fri Aug 11, 2023 4:44 pm
I would suggest booting to Linux via a disc or USB drive so you don't have to install it. That should give you a clue as to whether it's the software or hardware.
#3 Post by RealBlackStuff » Fri Aug 11, 2023 11:50 pm
Did you get the right touch pen with P/N or FRU 04W1477 ?
Grabber5.0
#4 Post by Grabber5.0 » Thu Aug 17, 2023 9:41 am
It doesn't require the pen to work.
