Repairs
X230-X280, X390 Series
RandomUsr890
Repairs
#1 Post by RandomUsr890 » Tue Aug 22, 2023 5:11 pm
Greetings, I am a new poster and have been following this forum for some time now. I have a ThinkPad X230, and I am experiencing issues with the trackpad and touchpoint. However, the keyboard is functioning properly. I am curious if this could be a driver or hardware issue. Any guidance you can provide would be greatly appreciated.
ZaZ
Moderator
Moderator
Re: Repairs
#2 Post by ZaZ » Tue Aug 22, 2023 9:10 pm
I wold suggest trying to boot to Linux either via a disc or USB drive. It do not need to install it and does not cost anything. If it works in Linux that would point to a software issue. If not that means the hardware is more likely the issue. Good luck my friend and welcome.
Re: Repairs
#3 Post by axur-delmeria » Wed Aug 23, 2023 1:35 am
You could try disconnecting the touchpad cable. If the Trackpoint works, then it's the touchpad causing the issue.
The touchpad and Trackpoint share one PS/2 port, so if one of them misbehaves, the other is affected.
RandomUsr890
Re: Repairs
#4 Post by RandomUsr890 » Wed Aug 23, 2023 8:18 pm
I have been running Linux for years on all my machines (Manjaro), so is this more likely to be a hardware issue? I've repaired a few ThinkPads & aren't someone new to tinkering around.
RandomUsr890
Re: Repairs
#5 Post by RandomUsr890 » Wed Aug 23, 2023 8:21 pm
You could try disconnecting the touchpad cable. If the Track point works, then it's the touchpad causing the issue.
The touchpad and Track point share one PS/2 port, so if one of them misbehaves, the other is affected.
I appreciate the advice, I will look around and find more information.
