x230 Wi-Fi card replacement and external antenna
Hello, i'm interested in replacing the wi-fi card on my x230 and maybe adding an external antenna as well. What is the best one i can get ?
I have to mention that i use linux and will flash skulls or heads on the machine so i'm afraid about driver incompatibility. If anyone has done this can i get some suggestion on card/adapters/antennas that work ?
Re: x230 Wi-Fi card replacement and external antenna
Note that the stock BIOS for the X230 has a whitelist that prevents you from installing other WiFi cards. Read up on https://github.com/n4ru/1vyrain in order to remove it. After that, you can install newer cards like the mini-PCIe version of the Intel AX210 (not the AX201 or AX211 because those are incompatible)--most AX210's are M.2 cards, but it may be possible to use a Mini-PCIe to M.2 adapter.
I've also heard people using the SATA ssd slot to instert a Wi-Fi board with antennas and use a mSATA instead, do you know an adapter that fits in x230 ?axur-delmeria wrote: ↑Sat Oct 21, 2023 10:45 pmNote that the stock BIOS for the X230 has a whitelist that prevents you from installing other WiFi cards. Read up on https://github.com/n4ru/1vyrain in order to remove it. After that, you can install newer cards like the mini-PCIe version of the Intel AX210 (not the AX201 or AX211 because those are incompatible)--most AX210's are M.2 cards, but it may be possible to use a Mini-PCIe to M.2 adapter.
My experience with X230 is that the built in antenna are sufficient. Lenovo spent $$$ engineering the OEM setup, no need to waste time and money reinventing the wheel.
sent from my iPhone
What I'm not sure about is the existing antennas' performance in the 6GHz band, which is new to WiFi 6E.
The X230 antennas are sub-optimal. Even with the Intel AX210 in there, the wireless reception is not as good as it is on other laptops I have access to. I'm not sure why though, as the antennas are surrounded by plastic on the front, top, and back. I think it might be that they are tuned for 2.4Ghz with little thought given to the 5Ghz band. When the X220 was released, which the X230 inherited the antenna design from, 5Ghz was not very common.
It's usually fine, but in environments with lackluster WiFi, it can be a problem. My 2015 Macbook Pro which I usually use alongside the X230 gets better reception with it's old ~2013 Broadcom wireless card, probably because it was designed with 5Ghz in mind.
Four 15" T61 Frankenpads collecting dust and one X62 that sees no use, but X201 and X230 in service.
Looking for X201 replacement keys/domes and 3mm stem to 4mm adapter.
by ThinkIsaac » Mon Dec 15, 2025 4:17 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 4542 Views
Last post by ThinkIsaac
can i swap the display + lid from an x220tablet to a x230 tablet chassis?
by rezenee » Wed Jan 21, 2026 8:03 am » in ThinkPad X200/X201/X220 and X300/X301 Series - 0 Replies
- 4538 Views
Last post by rezenee
WTB] [CAN-ON] X230 Motherboard with i7-3612QE (35W Quad Core)
by X230X220 » Mon Jan 26, 2026 7:35 am » in Marketplace - Forum Members only - 0 Replies
- 3739 Views
Last post by X230X220
Will X220 Tablet palmrest fit X230 Tablet?
by tts_rayhan » Sat Feb 07, 2026 7:28 pm » in ThinkPad X230-X280 / X390 Series - 0 Replies
- 3270 Views
Last post by tts_rayhan
