How to get into Thinkpads?
Got a question or suggestion about the forum? Ask or comment here, or
PM an admin or moderator.
DabigV
#1 Post by DabigV » Fri Oct 27, 2023 7:31 am
Hi guys,
First post here so please excuse my lack of computing jargon if you will, i’ve been looking to getting into Thinkpads for a long time now as i just enjoy computers and it seems like thinkpads are the only ones which ive found that do it all. Mac is way too institutionalised for me. Sometimes i just want an escape from such ‘work-machines’ as my son likes to call them.
I havent found any models that i specifically like but am looking for a fairly small, compact or old thinkpad. To be honest, i quite like the x230 but sometimes it feels a little fragile. So, i have been looking at the x60 and x61 series. I am really not sure where to start so if anyone could give some :D advice, or models or literally anything, i would be grateful
I have a background in programming so i have been looking for something to just chill out with and make my own. Thanks guys.
kfzhu1229
Re: How to get into Thinkpads?
#2 Post by kfzhu1229 » Fri Oct 27, 2023 10:05 am
If by old you mean like the more classic designed business class machines up to like early 2010s that is still compact, yeah that would be the X220/X230 series. My mum had one and well just like the T520/T530 series the palmrest plastics don't age the best and it had to be swapped out completely mid-life because it was in pieces. But they do have metal lids and metal bottom chassis which lasts well. Similarly T420s/T430s also have a metal bottom chassis (but plastic lid and I've seen one with a broken hinge sadly).
X60/X61 may be a bit too old to buy one today and dedicate it as your daily driver although it is certainly possible with the X61 if you really appreciate 4:3 screens.
Alternatively, the competitor for X220/X230 series is the HP Elitebook 2560p and 2570p. HP's offerings are bulkier but they are solid as a rock and they have socketed CPU's whereas X220/X230/T420s/T430s all have soldered ones.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
ZaZ
Moderator
Moderator
#3 Post by ZaZ » Mon Oct 30, 2023 12:04 pm
The chances you'll have an issue buying any ThinkPAd is low even if feels a little creaky. I don't know what you need or are looking to spend, but the X230 is more than a decade old and is limited in what it can offer you. Nowadays, I usually advise getting something with at least one of the low watt quad cores if you plan to keep and use it going forward.
olddog
#4 Post by olddog » Sat Nov 25, 2023 4:24 am
I have Thinkpads from the T42 to the W530 at home, and a W541 at work (and I see no reason to change it).
One of my T42 laptops is in daily use as a music machine; the W530 is my main machine; and I play around with the others as and when. I especially like the X230, T430, and the T61. The last is now a bit long in the tooth and RAM for it is expensive. But with enough RAM (min 8gb I suggest) the 30 generation machines are entirely usable, and unless you do a lot of video editing they are quite fast enough for normal tasks.
They are also cheap of course, so if they pack up after a couple of years it's no big deal.
I do suggest getting docks for all of them. They're very cheap now, and make life much simpler.
Anyway, if you're looking for a tip about which one to buy without breaking the bank, I'd definitely suggest a T430 or T530, or perhaps an X230 if you want something small. Those T machines are very upgradeable. Later models, less so.
And if you need a numeric keypad, go for a T or W 540 or a W541. The 540 machines have a nasty trackpad, so it's best to use them with a mouse.
Good luck.
Return to “Forum Notices, Questions and Suggestions”
Users browsing this forum: No registered users and 44 guests
