Lost wireless on t420 - can’t get it back
I hit the FN + F5 keys not knowing it would disable my wireless. I thought it would be a toggle but it’s not, and i’ve tried and searched everywhere but am unable to get back my wireless without insert a usb adapter.
Please tell me what I’m missing. There MUST be a way to get it back.
Thank you.
Thank you.
BillMorrow
- *Senior* Admin
Re: Lost wireless on t420 - can’t get it back
not sure what you mean when you say USB adapter..
Bill Morrow, kept by parrots
& cockatoos
Sysop - forum.thinkpads.com
~~~Mark Twain~~~
~~~Mark Twain~~~
He probably means a USB-wifi-stick.
@Dd777:
What OS are you using?
Switch off completely and remove charger/battery.
Open the machine up, remove/reinsert the wifi card, insert charger, try booting.
OK now?
@Dd777:
OK now?
AFAIK Fn+F5 cycles through four modes:
WiFi on, Bluetooth on
WiFi off, Bluetooth on
WiFi on, Bluetooth off
WiFi off, Bluetooth off
The other possible config is to bring up a menu that allows you to turn on/off the WiFi and Bluetooth separately.
Thank you all for your responses!!
Yes, I meant usb wifi adapter.
Tried removing and putting back the wifi card. No luck.
Running Windows 7.
My laptop does not have bluetooth. Hitting FN + F5 repeatedly doesn’t seem to do anything.
Hitting Windows + X brings up the mobility center, the TURN WIRELESS ON is greyed out.
Completely stumped. May need to stick to adapter.
Thanks again.
Running Windows 7.
Thanks again.
I see from other forums there is supposed to be a windows that opens when you press FN + F5, but that doesn’t happen on my laptop.
Try to install Lenovo Hotkey Features Integration version 3.81.
Be up to date on vcredist x32 and x64 first.
sent from my iPhone
Thank you for your reply, but when I entered my serial number, it wouldn’t let me download the Hotkey file because it’s not compatible with the T420.
Hotkey 3.81.0100 here: https://download.lenovo.com/ibmdl/pub/p ... vu23ww.exe
Newer 3.89.0100 here: https://download.lenovo.com/ibmdl/pub/p ... vu43ww.exe
Thank you for the link for those files. Did the install and now when I press FN + F5 it says you must use the hardware switch to turn on the Wi-Fi but I don’t have a hardware switch on my laptop. When you press FN plus F6 it brings up the communication window which allows me to access the WebCam, or change the audio settings which I did not have before, but no luck with the Wi-Fi, unfortunately.
The T420 does have a WiFi hardware switch. I believe it's on the back right, next to the SD slot. See this pic:
If it's stuck in the off position, switch it on. If it's in the on position, and the SW detects it as off, the switch may be broken.
OMG I have egg on my face. As the previous poster pointed out, there is a wifi hardware switch. I actually saw and thought it was some type of EJECT mechanism because it’s so much smaller than the diagrams I’ve seen of the wifi switches.
My apologies and appreciation to those who took up their precious time to try to help me. Thank you!!
At least the poster who linked the download files to the hotkey switches, enabled me to get access to my WebCam, low resolution as it is, that I did not have before.
Restart automatically when power comes back on
by Thinkpad2024 » Tue Mar 31, 2026 6:12 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 2 Replies
- 740 Views
Last post by Thinkpad2024
Wed Apr 01, 2026 8:49 am
Virtualization on T420
by Berator » Sat Nov 22, 2025 10:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 6967 Views
Sun Nov 23, 2025 11:56 am
- 4 Replies
- 6982 Views
Last post by Kiriakos
Sun Feb 15, 2026 12:25 pm
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10651 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
