Getting OSD to work in windows 7 t61
I recently installed Windows 7 SP1 on my Thinkpad T61. After a bit of poking around I got all drivers working other than the on screen display, the icons that pop up to show you volume adjustment mute and other functionality etc. I installed Hotkey Features Integration for Windows driver package and despite there being a menu to adjust the OSD settings in the display menu, It does not seem to function at all.
Any pointers on how I can get this to work would be great.
Re: Getting OSD to work in windows 7 t61
Make sure vcredist is up to date, then reinstall hotkey features, go for version 3.81. The newer versions don't work properly on T61 and other laptops Sandy Bridge-era and older.
sent from my iPhone
Thanks for the response. I believe I installed 3.89. I will try 3.81 and update vcredist.
if anyone ends up reading this 3.81 is the correct version to use
zoltan87
Also just a heads up, the 3.81 version is the correctly working one on Windows 8.1 too, on a T60 (and I would assume T61). I remember spending so much time trying to figure out why my OSD settings were not displayed correctly, until I managed to find out that not all versions are compatible with newer Windows versions. Although I always assumed the issue was present only from Win 8 and upward, turns out Win 7 is already problematic in this regard.
Thinkpad T60, 15" Flexview, with mods (Xiphmont's LED mod, T500 heatsink, cpu undervolt, reinforced frame)
Thinkpad T601, 15" Flexview, with mods (Xiphmont's LED mod, T500 heatsink, cpu undervolt, reinforced frame)
Thinkpad X32
Thinkpad T22
NEC ProSpeed SX/20
Thinkpad X32
Thinkpad T22
NEC ProSpeed SX/20
- 10 Replies
- 10113 Views
Sun Dec 21, 2025 4:38 pm
P15 gen1 ... will a 1TB + 4TB NVMe SSD pairing work?
by portsample » Thu Nov 27, 2025 8:23 pm » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 2 Replies
- 7830 Views
Last post by portsample
Thu Nov 27, 2025 10:00 pm
T470S suddenly stopped booting. Screen keeps black while everything else seems to work
by irock » Sat Feb 28, 2026 2:34 pm » in ThinkPad T430-T495 / T530-T590 Series - 9 Replies
- 6215 Views
Last post by irock
Mon Mar 16, 2026 12:57 pm
X61s screen backlight doesn't work. Faulty mobo?
by huohuo » Tue Mar 03, 2026 6:35 pm » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 6744 Views
Last post by huohuo
Sat Apr 04, 2026 3:43 pm
Users browsing this forum: No registered users and 367 guests
