Hello. I've posted a few times, but long enough ago that I forgot my original username, e-mail, etc., and had to re-register. Anyway...
I've had reason to quite regret that on my T420 Thinkpads (I own two), the power switch is part of the keyboard. This is what happened: on the used T420 I bought onlly a couple months ago, the monitor failed. So since nothing else was obviously wrong with it and my other T420 was working poorly at that point anyway, I took the latter T420 apart and transplanted the fully functioning screen. They're not the same model T420, but I am hopeful that the screen will still work. But I can't test it yet. While reassembling the one that received the good screen, my clumsy fingers snapped the keyboard's ribbon cable. I tried to transplant the "screen donor" T420's keyboard, but the exact same thing happened--my clumsy fingers snapped the ribbon cable. The problem is that at least on the T420, the power switch is part of the keyboard. Thus, I have rendered both laptops useless until the replacement T420 keyboard I ordered gets here next week. (As far as I know, there is no other easy way to turn a T420 on.)
Since I haven't used another Thinkpad model in a few years, I can't remember whether other T series models (such as the T400 I was very familiar with) have the power switch on or off the keyboard. But this is my question: Do you agree with me that attaching the power switch to the keyboard was a terrible idea? If I had been aware of this, I would have stuck with the T400 last time I bought a Thinkpad.
is it a design flaw for power switch to be part of keyboard?
Re: is it a design flaw for power switch to be part of keyboard?
T400 power cable is also in the keyboard.
I've changed keyboards hundreds of times and only broke one cable. Practice, you will get better.
I hate hate hate how the power cable is routed on t470.
sent from my iPhone
Yes, as TPFanatic mentions - there are ups and downs to both designs.
If you get a docking station, it is possible to turn your laptop on with the power button on the dock.
3D model for top cover of (most) ThinkPad 760 models (part 29H8966-CD / 29H9184)
by btober » Sun Mar 29, 2026 9:15 am » in ThinkPad Legacy Hardware - 2 Replies
- 1051 Views
Last post by btober
Thu Apr 02, 2026 1:54 pm
- 11285 Views
Last post by dcfbf
Wed Jan 21, 2026 2:32 pm
T450 Will Not Power Up
by shajoe44 » Mon Nov 10, 2025 8:23 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 4573 Views
Last post by quietude38
Fri Jan 23, 2026 11:37 am
T480 won't boot - power button just flashes.
by kae2020 » Fri Dec 05, 2025 11:20 am » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 11727 Views
Last post by kae2020
Sun Dec 07, 2025 2:03 pm
Users browsing this forum: No registered users and 66 guests
