Windows 11 on my ThinkPad L570
ThinkPad560X
I installed windows 11 Pro on my ThinkPad L570. 4GB RAM, 1TB M.2 and has an Intel(R) Core(TM) i5-7300U CPU @ 2.60GHz 2.70 GHz. Windows 11 Pro build 21H2, OS Build 22000.2538. I installed windows 11 Pro by my windows 11 Pro OEM install disc "Yes Microsoft still has DVDs for OEM" It was a normal install, shows format said partition and then installed windows and then the paper airplane setup your name and activate windows screen. Not once it said this machine can't run this version of windows and did no hack to bypass install. Not sure if it was the OEM DVD or not. But from what I read Intel 8th gen is the lowest windows 11 will fully support. I had windows 11 on this machine for over a year "Don't use it much" and I haven't gotten a message saying this machine isn't supported. So is this cpu supported?
IBM: 760XD,770Z,600X,240,560X,560Z,570,380Z,390X,i1200,i1400,
A22m,A22e,A30,G40,R31,R40,R50,R60,R61,R400,R500,
T20,T23,T30,T40,T43,T60,T61,T400,T400s,T500,W500,W700,
X21,X30,X41,X41T,X60,X60T,X200,X200T,X300,X120e,Z60m,Z61t
T410|T510 to T480|T580
L440|L450 to L480|L580
X220 - X280
X220 - X280
Re: Windows 11 on my ThinkPad L570
I need to get a copy of that DVD.
ThinkPad560X
https://www.ebay.com/itm/285637995926?h ... R6zhq8edYw
Windows 11 will probably be the last OS to come on disc from what I am hearing as new desktop and laptops are shipping without disc drives anymore. Retail you still get USB flash drive.
X220 - X280
X220 - X280
The installer from the bootable install media won't check the computer's CPU model/generation and if the TPM is version 2.0.
In that case the minimum TPM version required is 1.2. Bypass is still required if a TPM is not present at all.
Microsoft even mentions this in their knowledge base article:
The only 7th gen laptop CPU "officially" supported by Windows 11 is i7-7820HQ. Several Skylake and Kabylake desktop workstation SKUs also appear on the supported processor list.Important: You should verify that your device meets minimum system requirements before you choose to boot from media, because it will allow you to install Windows 11 if you have at least TPM 1.2 (instead of the minimum system requirement of TPM 2.0), and it will not verify that your processor is on the approved CPU list based on family and model of processor.
ThinkPad560X
I think Microsoft should support 7th gen as all my ThinkPads T570, T470, L570, L470 are the 7th gen CPU and not the 6th gen and the 7th gen supports UEFI, TPM 2.0 and Secure boot. I ran health check on my L570 as it wasn't getting the latest Win11 build, and it shows everything is green but the CPU. "Not Supported" But Microsoft's big thing when W11 came out was you need TPM 2.0, which these machines have. You can bypass to get the latest build of 11 but you have to do the same thing when bypassing a windows 11 install on unsupported hardware. For me I have the OEM Windows 11 Pro disc and it didn't say CPU not supported and installed fine. But I just reinstalled Windows 10 Pro and just left it at that, as I am not sure if security updates will install or not as well being on an old build.
I think when Windows 12 comes out we may get into the smartphone cycle where only Android OS XX can update to this android XX version and then cannot update to latest unless get a newer phone every 3 years.
X220 - X280
X220 - X280
There's a very specific reason for this, as mentioned in this Ars Technica article from 2021:
If the decision to support one specific 7th-generation Core i7 laptop processor strikes you as odd, you don't need to look far for an explanation—this just happens to be the CPU included in Microsoft's Surface Studio 2, which Microsoft still sells but has not updated in three years.
T480 never offered update to Windows 11 24H2
by cage » Wed Nov 12, 2025 3:10 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 8640 Views
Last post by pianowizard
Wed Nov 19, 2025 9:08 pm
Windows password not being accepted...
by PAL_Thailand » Thu Nov 13, 2025 12:50 am » in ThinkPad X20/X30/X40 Series incl. Tablets - 1 Replies
- 5751 Views
Thu Nov 13, 2025 1:05 am
Found Windows 7 En-US recovery media for T440p
by CicadaCool » Sun Nov 16, 2025 10:40 am » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 7255 Views
Mon Nov 17, 2025 1:28 am
- 10 Replies
- 10087 Views
Sun Dec 21, 2025 4:38 pm
