Wifi Card upgrade suggestions?
babysheegoth
Looking upgrade wifi card to something as modern as possible that also makes sense financially.
Also how to remove whitelist from middleton bios?
Re: Wifi Card upgrade suggestions?
Middleton bios should already have removed the mpcie whitelist.
Ax210 soldered or adapted onto mpcie format card is the current most modern upgrade.
Other cheap popular choices are 7260ac, 6205n, and 6300n.
If you’re running Windows newer than 7, Anything is better than the 4965agn which crashes Windows due to no proper compatible driver.
sent from my iPhone
Gonzaleitor
I have them 6300n and it works great. The bottleneck is on the rest of the hardware...
babysheegoth
6300n fits in t61? it looks different from ebay listings then the wifi card currently in my laptop?Gonzaleitor wrote: ↑Sat Jan 13, 2024 9:15 amI have them 6300n and it works great. The bottleneck is on the rest of the hardware...![]()
Some cards are full size, some cards are half-size and need an extender bracket, as seen below:
Gonzaleitor
Yup, just as RBS said.babysheegoth wrote: ↑Mon Jan 15, 2024 12:46 am6300n fits in t61? it looks different from ebay listings then the wifi card currently in my laptop?Gonzaleitor wrote: ↑Sat Jan 13, 2024 9:15 amI have them 6300n and it works great. The bottleneck is on the rest of the hardware...![]()
babysheegoth
I'm having trouble finding extender bracket on ebay if there's a search term or another I place I need to look for it?RealBlackStuff wrote: ↑Mon Jan 15, 2024 2:15 amSome cards are full size, some cards are half-size and need an extender bracket, as seen below:
Something like this? https://www.ebay.com/itm/301239090014babysheegoth wrote: ↑Mon Jan 22, 2024 11:56 amI'm having trouble finding extender bracket on ebay if there's a search term or another I place I need to look for it?
babysheegoth
https://www.ebay.com/itm/114137088482?m ... media=COPY
There's multiple listing some saying Dell model in them. This one saying thinkpad. Is this the right 6300n?
Does it matter what brand the listing labels them as or are they interchangeable in all laptop brands?
Certain laptop models (most Thinkpads included) have BIOS whitelists that prevent end-users from installing WiFi cards other than the ones that were certified with said laptop models. Installing the Middleton BIOS removes that whitelist on your T61, so it doesn't matter which brand of WiFi card you purchase.babysheegoth wrote: ↑Tue Jan 23, 2024 9:09 amDoes it matter what brand the listing labels them as or are they interchangeable in all laptop brands?
I updated my 2200 to a 6205 and then a 6300 in my T430. Didn't really notice any difference!
Keith
(Formerly 600E, T21, T30, T40, T41, 2xT42, 2xT61p, T420, 2x Ideapad K1)
(Currently 4xT430, 2xT460, H520S, M910q, M920q, M70q, M80q)
Well, they're all WiFi N cards, and a minor upgrade (2200 --> 6205) at best. The 6300's 450Mbps max only comes into play if your router has 3 transmit antennas. For casual internet use you won't really notice it.
Our WiFi access points at home are WiFi AC1200 (300+866). With two laptops with Intel 6205's connected on the 5GHz band, FTP file transfers between them averaged around 15 megabytes/sec, with bursts up to 20 megabytes/sec. With two laptops with WiFi AC cards (Intel 8260 and 9260) it averages > 20 megabytes/sec. Note that the source and destination directories are on RAM disks to ensure maximum throughput (minimizing bottlenecks caused by writing to HDD or SSD).
After flashing Middleton BIOS and upgrading CPU to T9300, how to upgrade the original 4965AG to a dual Wifi+Bluetooth card ? Is the AC7265 good ? The 4965AG has 3 connectors (black/grey/white cables), but the AC7265 has 2. Which cables should be connected ?
Regarding Bluetooth, can Windows 7 work with both radios, the old BT2 module in the lid and a new BT4 chip on mPCIe Wifi card ? My desktop W7 does not want two generic BT dongles, the second shows up with a yellow exclamation mark in Device Manager.
windows will only work with one bluetooth radio. so it'd be like you said, second card with a yellow exclamation mark.
gray wire goes to Main;
black wire goes to Aux;
white wire goes to extra pin, if present -- tape over metal contacts and leave unplugged otherwise.
each antenna is functionally the same so it doesn't actually really matter where they go, but Id is how Lenovo intended.
sent from my iPhone
Signal quality is better with 3x3 MIMO. But you need to make sure your router supports that (most don't). If your router doesn't, it's better to get an AX210. But the specific model depends on the OS you want. Older cards don't support newer Windows and newer cards can't be run on older versions.
I have a Netgear R7000 AC1900 router with 3 antennas. I do quite a lot of file transfers over wifi when backing up and it basically wasn't noticeable.axur-delmeria wrote: ↑Sun Feb 11, 2024 11:47 pmThe 6300's 450Mbps max only comes into play if your router has 3 transmit antennas. For casual internet use you won't really notice it.
Keith
If you have an AC1900 router, upgrade all your devices to WiFi AC if possible, then set the router to transmit WiFi-AC only (instead of AC+N) on the 5GHz band.
W520 and WiFi connection speed issue
by jdwis » Sat Nov 01, 2025 7:11 am » in ThinkPad W500/W510/W520 and W700/W701 Series - 8 Replies
- 24705 Views
Last post by jdwis
Wed Nov 12, 2025 11:57 am
Can't enter wifi-Password in a hotel or anywhere else?
by RealBlackStuff » Mon Dec 22, 2025 2:31 am » in Windows 10/11/etc. - 2 Replies
- 4202 Views
Last post by Scorpion8
Mon Dec 22, 2025 6:38 pm
XP T60 randomly stops seeing my wifi network.
by Glaurung-quena » Thu Jan 29, 2026 5:30 pm » in ThinkPad T60/T61 Series - 5 Replies
- 4970 Views
Last post by Glaurung-quena
Sat Jan 31, 2026 10:06 am
free: ThinkPad 760 memory card w/ ram
by PiZzA EnGiNeEr » Fri Nov 14, 2025 12:16 am » in Marketplace - Forum Members only - 3 Replies
- 7461 Views
Mon Nov 17, 2025 12:29 pm
Users browsing this forum: No registered users and 197 guests
