Do you guys know if the camera on the X1C4 works OK on Windows 11?
Lazy me, I just transplanted the factory 256GB SSD drive from my X1C9 after upgrading it to 1TB. The original one is SATA, and probably much slower, though it seems more power-efficient. The new one (Kioxia BG5) is rated at 3.3v and 2.5A, while the old one (00JT021, LiteON L8H-256V2G) is 3.3v and 0.95A.
It booted up just fine, so I decided to just go with Windows 11. It requiered some manual work because not everything is installed automatically:
Works with Windows 10 drivers from Lenovo's site:
* Realtek Card Reader.
* Chipset (INF).
* Power management device.
From Windows Catalog:
* Mobile 6th Generation Intel(R) Processor Family I/O Integrated Sensor Hub - 9D35.
Now there are no unknown devices in the Device Manager, but when I tried to fire up the camera to check, it complains that it can't find any camera. I then recalled that I usually disable some "ports" in the BIOS to save power and indeed, I had the WWAN and Camera disabled. I re-enabled them but guess what? Nada!
Now, I have three machines of this type and I do remember that the camera in one of them doesn't work, but I don't remember which one. I know I could simply boot up Linux and check, but when I visited Lenovo's site I noticed that they released a driver patch for the camera... for Windows 11! It may very well be the only device driver intended specifically for Windows 11 for this machine. So I'm wondering: is it a known issue?
Windows 11 on the X1 Carbon Gen 4 / 4th
- 13292 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
- 8840 Views
Last post by dcfbf
Wed Jan 21, 2026 2:32 pm
T14 Gen 3 compatible 40-pin 4-lane display cables
by LimesKey » Fri Oct 24, 2025 3:22 pm » in Thinkpad T14/T15/T16 - 3 Replies
- 8234 Views
Sun Oct 26, 2025 12:57 am
T14 Gen 1 AMD - problems with wwan card: whitelist?
by piripuz » Mon Nov 17, 2025 4:42 am » in Thinkpad T14/T15/T16 - 4 Replies
- 10532 Views
Last post by piripuz
Wed Nov 19, 2025 5:56 am
