Unknown bios password
newyorkpaulie
I am getting an eBay T61 that I’ve learned has a password locked bios. I found this out after I bought it. It should arrive tomorrow. I’ve looked around and one “remedy” was to remove the CMOS battery, wait an hour and then plug it back in, returning things to the factory setting. Anyone have some help here? Thanks!
Re: Unknown bios password
If removing the CMOS doesn't help you'll have to short some pins on the EEPROM to clear out the password.
Thinkpads
R51 1829-W1C 2GB RAM
R500 2716-RY6 8GB RAM
T520i 4239-47U, 16GB RAM
T530 RIP
P15 G2 20YR 16GB RAM
SK-8835 Ultranav keyboard Japanese layout
T530 RIP
Apart from the CMOS, you also need to remove main battery and charger.
Waiting a minute with CMOS out is long enough, IF that laptop only has a Power-On-Password.
If not, to unlock the BIOS you'll have to take the mobo out, but leave it within the chassis.
Make a drawing of where the screws are removed from and tape them on it.
Then reconnect the keyboard and use two screws to keep the keyboard "attached" to the frame.
Only turn those screws 2 or 3 times, to avoid damaging the keyboard.
Attach only the charger, then hook up to an external monitor.
Find the password-EEPROM using these pictures.
They also show which pins to use for the SVP-removal.
That EEPROM is partially 'hidden' under some plastic cover (can be lifted), as seen below:
Since it is on the bottom of the mobo, you'll need to somehow stand it up with the mobo-bottom facing you, or have someone hold it.
Get some sharp-pointed tweezers or similar and follow this youtube video: https://www.youtube.com/watch?v=5z0HdLqgR_I
You may need 3 or 4 hands for that, but check that youtube a few times first.
Alternative: find another Thinkpadder in or around NY to do it for you.
Removing T480 admin BIOS password
by bravo3 » Fri Jan 23, 2026 5:51 am » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 4732 Views
Last post by case11
Fri Mar 13, 2026 5:50 pm
Windows password not being accepted...
by PAL_Thailand » Thu Nov 13, 2025 12:50 am » in ThinkPad X20/X30/X40 Series incl. Tablets - 1 Replies
- 5720 Views
Thu Nov 13, 2025 1:05 am
Can't enter wifi-Password in a hotel or anywhere else?
by RealBlackStuff » Mon Dec 22, 2025 2:31 am » in Windows 10/11/etc. - 2 Replies
- 4180 Views
Last post by Scorpion8
Mon Dec 22, 2025 6:38 pm
- 2 Replies
- 8500 Views
Last post by LayaVulpes
Tue Oct 21, 2025 12:12 pm
Users browsing this forum: No registered users and 94 guests
