We had some heavy rain yesterday and my bag (containing my T400) got soaked. I tried to turn it on just now, and it appeared to boot at first.
I entered my geli(8) password and FreeBSD began to load, then the screen and status LEDs began to flicker rapidly. I tried holding the power button, but for the first time it didn't do anything, so I removed the battery.
When I turned it back on again, it didn't even show the ThinkPad boot screen; it just sat there flickering.
I have opened the case up and looked inside. I hve checked the RAM, the CPU, the SSD: even the DVD drive; and everything seems fine, yet the problem still persists.
Does anyone have any idea what's wrong and how I can fix it? Or is my laptop now borked? Thanks!
T400 Not booting, lights flickering
hellfire103
I have a T400, but more will soon follow...
Re: T400 Not booting, lights flickering
I'd let it dry, then pull everything out(drive, memory, optical, Wifi, battery). After, plug in the power to see if it beeps when powered. If so you can try putting parts back to see if you can find the culprit. If it doesn't beep, the likely board has a problem somewhere. It can be replaced if you want.
Gonzaleitor
I'd also try with rice to absorb all the humidity.
T470S suddenly stopped booting. Screen keeps black while everything else seems to work
by irock » Sat Feb 28, 2026 2:34 pm » in ThinkPad T430-T495 / T530-T590 Series - 9 Replies
- 6141 Views
Last post by irock
Mon Mar 16, 2026 12:57 pm
T400 Upgrade?
by SapphiRummer » Thu Feb 12, 2026 12:39 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 2 Replies
- 1999 Views
Thu Feb 12, 2026 4:39 am
- 27377 Views
Sat Oct 25, 2025 8:30 am
T450 Will Not Power Up
by shajoe44 » Mon Nov 10, 2025 8:23 pm » in ThinkPad T430-T495 / T530-T590 Series - 2 Replies
- 4573 Views
Last post by quietude38
Fri Jan 23, 2026 11:37 am
Users browsing this forum: No registered users and 68 guests
