Ugh. For years it was possible to upgrade from 7 to 10 for free with the factory key of old machines.
Since my X220 always ran Windows 7, I never bothered to activate Windows 10 on it, knowing that I could do that at any time (despite M$ claiming one year promotional period). And now, that I finally decided to give Windows 10 a go, I can no longer activate it.
It seems that a LOT of people were upgrading to Windows 11 using this path, so M$ became upset and permanently disabled it. This happened on September 20, 2023.
I'm not aware of any way around this. Might as well get a second hand W10 COA.
You can no longer install Windows 10 with a 7/8 key
Re: You can no longer install Windows 10 with a 7/8 key
Try the Micro Win 10 by Dark Reverser as mentioned here on a spare drive.
Once activated, you probably should then be able to install a 'regular' W10, OR W10 LTSC 2019/2021.
Come to think of it, maybe dump Micro$haft altogether and install Linux?
Have you seen the classic ThinkPad prices these days?
by dcfbf » Tue Dec 02, 2025 8:24 pm » in Off-Topic Stuff - 11 Replies
- 13048 Views
Last post by edik
Wed Apr 08, 2026 6:43 pm
W11: Micro$haft are Moving your Files into the Cloud without you knowing!
by RealBlackStuff » Sat Jan 03, 2026 2:23 am » in Windows 10/11/etc. - 5 Replies
- 9203 Views
Last post by Saucey
Mon Jan 26, 2026 5:43 pm
Can I restore T14 Gen2 after reset using backup of SSD?
by Thinkpad2024 » Sat Nov 01, 2025 9:33 pm » in Thinkpad T14/T15/T16 - 4 Replies
- 9314 Views
Sun Nov 02, 2025 2:30 pm
Can X1-E Gen2 use DDR4-3200?
by Thinkpad2024 » Mon Dec 01, 2025 5:27 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 1 Replies
- 4390 Views
Last post by dcfbf
Mon Dec 01, 2025 6:01 pm
