SOLVED - Does T14 Gen2 have a USB-C port with DP Alt Mode?
2020 New name Series after T430-T490 / T530-T590
Thinkpad2024
#1 Post by Thinkpad2024 » Wed Mar 27, 2024 9:58 am
I'm thinking of buying this docking station: https://www.ebay.com/itm/133322297742?i ... ULCDs4XQYw. It says it must have an available USB-C port with DP Alt Mode or Thunderbolt 3 technology. I know the T14 has a USB-C port but I don't know about the rest.
Re: Does T14 Gen2 have a USB-C port with DP Alt Mode?
#2 Post by axur-delmeria » Wed Mar 27, 2024 11:58 am
From the T14 Gen2 AMD PSREF https://psref.lenovo.com/syspool/Sys/PD ... D_Spec.pdf
2x USB-C 3.2 Gen 2 (support data transfer, Power Delivery 3.0 and DisplayPort™ 1.4a)
From the T14 Gen2 Intel PSREF https://psref.lenovo.com/syspool/Sys/PD ... l_Spec.pdf
2x Thunderbolt 4 / USB4® 40Gbps (support data transfer, Power Delivery 3.0 and DisplayPort™ 1.4a)
Thinkpad2024
Re: SOLVED - Does T14 Gen2 have a USB-C port with DP Alt Mode?
#3 Post by Thinkpad2024 » Wed Mar 27, 2024 2:16 pm
Return to “Thinkpad T14/T15/T16”
