X1 Carbon replacement keyboard - stiff trackpad button
Thinkpad2024
I had a keyboard problem and replaced it. But the right trackpad button on the new keyboard is very stiff, making it difficult to use. Other than replacing the keyboard again, does anyone have any suggestions for fixing this problem? Or, if replacement is the only option, can someone recommend a reliable vendor?
Re: X1 Carbon replacement keyboard - stiff trackpad button
Reliable vendor? Where did you get the replacement keyboard last time?Thinkpad2024 wrote: ↑Fri Mar 29, 2024 11:07 amI had a keyboard problem and replaced it. But the right trackpad button on the new keyboard is very stiff, making it difficult to use. Other than replacing the keyboard again, does anyone have any suggestions for fixing this problem? Or, if replacement is the only option, can someone recommend a reliable vendor?
It sounds to me like a key is not seated properly. It's common with laptop keyboards. Just press it hard, sometimes it fixes it.
- 11100 Views
Last post by dcfbf
Wed Jan 21, 2026 2:32 pm
- 13861 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
Enabling trackpad cannibalizes the trackpoint
by dcfbf » Tue Nov 25, 2025 4:59 pm » in ThinkPad T60/T61 Series - 3 Replies
- 8480 Views
Last post by dcfbf
Thu Nov 27, 2025 8:51 pm
Has anyone modified the hinge/springs in a trackpad?
by jonzilla5000 » Tue Jan 06, 2026 6:28 pm » in Thinkpad T14/T15/T16 - 0 Replies
- 4784 Views
Last post by jonzilla5000
Users browsing this forum: No registered users and 50 guests
