This happened to me with both computers. The first time I was installing a backlit keyboard in my X270 (a lot of disassembly). Afterwards the button light would not come on and it would not start. I thought I had done something wrong or the keyboard was faulty so I reinstalled the old keyboard and the same thing happened. At this point I figured I had broken something, but had the idea of plugging in the AC adapter. This resulted in the button light coming on, but it still didn't boot. At this point I just left it alone and almost 2 minutes later, it booted to set the date and time (I had to disconnect the CMOS battery to install the keyboard), and then it miraculously booted. I then reinstalled the new keyboard and the same sequence occured (it's amazing how undaunting a procedure becomes after you do it three times).
Skip forward a couple weeks and I bought a X280 on eBay and replaced the SATA M2 SSD with a NVME SSD. Very easily accomplished, but again, it would not boot (I cloned the OS to the new SSD prior to the reinstall) without plugging in the AC adapter, however his time it booted much faster because I had not unplugged the CMOS battery.
This is something I had not heard of before and found it odd (I know I did a similar SSD swap in the X270 years ago, but I don't remember this happening, but it might have). I wonder if it was because I turned off the internal battery in the BIOS (UEFI) combined with the back cover switch. Anyone know?
X270/X280 won't start after removing back over without AC adapter
onespeedbiker
Re: X270/X280 won't start after removing back over without AC adapter
AFAIR, once you turn off the built-in battery in the BIOS, the laptop will not power on without connecting an AC adapter first. It is by design.
onespeedbiker
I did not know that. Thanks
Removing spacebar on the X220
by Kocane » Fri Dec 19, 2025 5:24 pm » in ThinkPad X200/X201/X220 and X300/X301 Series - 2 Replies
- 3903 Views
Last post by Kocane
Sat Dec 20, 2025 9:19 am
Removing T480 admin BIOS password
by bravo3 » Fri Jan 23, 2026 5:51 am » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 4801 Views
Last post by case11
Fri Mar 13, 2026 5:50 pm
T440P; help me with removing whitelist & unlocking advanced menu
by LUC1FER » Sun Mar 15, 2026 11:27 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 1421 Views
Mon Mar 16, 2026 1:14 am
X1 tablet gen 3 won't boot after SSD replacement
by babblefish » Thu Feb 19, 2026 10:22 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 7 Replies
- 4422 Views
Last post by babblefish
Fri Feb 20, 2026 7:44 am
Users browsing this forum: No registered users and 89 guests
