Q: Does A31 Have A Lid Close Switch?
TPFanatic
#1 Post by TPFanatic » Wed May 01, 2024 3:48 pm
Does A31 have a lid-close sensor? Mine doesn’t seem to have one, or it does and it doesn’t work. Since it predates T40/R50 which had the mechanically operated switch, and I see nothing like it on A31, does it just not exist?
kfzhu1229
Re: Q: Does A31 Have A Lid Close Switch?
#2 Post by kfzhu1229 » Wed May 01, 2024 3:56 pm
Of course it does, it's tucked away nicely in the top right side of the palmrest. Seems like the ThinkPads don't like using hall sensors, which actually there are mechanical hall sensors at the time, I remember seeing one such mechanical one on Dells, where it is two pieces of metal inside a vacuum glass container, if you put a magnet close to it you can see the two pieces of metal actually touching each other.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
TPFanatic
#3 Post by TPFanatic » Thu May 02, 2024 6:52 am
ah. I found the spot you’re talking about. Something fell out of the laptop that seemed to come from that area, now i know what it was lol.
kfzhu1229
#4 Post by kfzhu1229 » Thu May 02, 2024 2:28 pm
Yeah my A30 lid sensor plastic did fall off once before as well and it's easy to miss until you realise lid close does nothing...
UXGA:
