I have a T520boosted by an SSD. It does everything I need, so I decided to fix its exterior a bit since a drop had some of the plastics cracked and later fallen off.
So I purchased a used palmrest, which came with a touchpad and a fingerprint scanner. Notice that my laptop originally did not have a fingerprint scanner.
I replaced the entire palmrest component and connected the touchpad cable. The fingerprint scanner works fine, it is recongized by Windows Hello.
However, I have some issues with the touchpad and mouse buttons. Occasionally the touchpad TAP or one of the two mouse buttons (sometimes the left one, sometimes the right one) will stop working. And so, I can scroll with the touchpad, but clicking won't work.
Could this be due to some sort of incompatibility between my motherboard and the fingerprint reader or have I just purchased a defective part? If so, can the touchpad alone be replaced (maybe use my old one with the new palmrest)? I haven't tried to disassemble that yet, but I saw that it's held by two screws.
Thanks in advance!
Thinkpad T520 touchpad replacement issu
Re: Thinkpad T520 touchpad replacement issu
Those buttons are part of the keyboard.
The touchpad is separate and can be replaced with your 'old' one.
kfzhu1229
Touchpad button assembly is easy enough to separate and swap, trackpoint buttons are part of the keyboard.fredboyce wrote: ↑Thu May 09, 2024 3:12 amCould this be due to some sort of incompatibility between my motherboard and the fingerprint reader or have I just purchased a defective part? If so, can the touchpad alone be replaced (maybe use my old one with the new palmrest)? I haven't tried to disassemble that yet, but I saw that it's held by two screws.
Thanks in advance!
Fairly confident swapping that across would fix your problem as it sounds like the membrane traces on the touchpad button are damaged and shorted together with some resistance. Those are surprisingly easy to damage - just click the mouse button with a sufficiently wet finger and it's possible the button will stop working once the liquid seeps through
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Disable Touchpad on ThinkPad T490?
by Clueless in Seattle » Tue Jan 20, 2026 9:57 pm » in ThinkPad T430-T495 / T530-T590 Series - 3 Replies
- 4784 Views
Last post by dcfbf
Sun Feb 08, 2026 1:41 am
ThinkPad T520 coreboot
by mcq » Wed Apr 08, 2026 10:27 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 488 Views
Last post by mcq
by londonwhite » Thu Jan 15, 2026 2:21 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 8 Replies
- 10646 Views
Last post by deickos
Sat Apr 04, 2026 11:32 am
FHD IPS for T520
by TP_ » Mon Feb 16, 2026 1:25 am » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 3 Replies
- 6547 Views
Last post by dcfbf
Mon Feb 16, 2026 3:41 pm
Users browsing this forum: No registered users and 44 guests
