T430 - how can I use ExpressCard slot?
br1anstorm
I have an T430 which I use as a spare/backup laptop. I notice it has an "Expresscard" slot (filled by a dummy plastic tray). I cannot recall ever using an Expresscard - indeed I'm not entirely sure what they look like or can do, and I understand they are more-or-less obsolete.
However.... I'm just wondering if it is possible to find an adapter which goes into the Expresscard slot and which holds a small ("half-size") mSATA SSD?
I ask because I have already successfully fitted an mSATA SSD into the WWAN slot inside the T430 - which gives me one extra drive. It just occurred to me that it would be useful to have another drive. Doesn't have to be bootable - it could just provide storage capacity for data.
But I'm not entirely sure what to look for and what the detailed spec needs to be for such an Expresscard/mSATA SSD adapter (assuming such a thing exists). An online search throws up a range of items, most of which seem to be for building into desktops, not sliding into an existing Expresscard slot in a laptop
Re: T430 - how can I use ExpressCard slot?
Have you considered replacing the CD/DVD with an SSD caddy and SSD drive?
br1anstorm
Ah, you must be clairvoyant! Yes, been there, done that ... and it is an easy and convenient modification. But right now the caddy is on the shelf, the SSD is in another laptop, and I have reinstated the original CD/DVD drive - because I still use discs.RealBlackStuff wrote: ↑Wed May 29, 2024 9:51 amHave you considered replacing the CD/DVD with an SSD caddy and SSD drive?
So yes, I could go the CD/DVD caddy route again. But I was just interested in exploring what - if anything - could be done with the Expresscard slot as another possible option.
I guess what I'm looking for is something like this https://thinkmods.store/products/expres ... me-adapter, which takes an NVMe (m.2?) SSD. I'd like a similar adapter which takes an mSATA SSD like the one that fits in the WWAN slot. Does such an adapter exist?
No, it doesn't exist, because it's more trouble than it's worth-- an Expresscard is basically a hotplug-capable PCIe x1 slot. In order to make an Expresscard --> mSATA adapter, you'd need to squeeze in a PCIe SATA controller chip while leaving enough open space for the mSATA SSD. It might be possible to design (though I have serious doubts), but frankly, it's pointless because mSATA is a niche SSD format.br1anstorm wrote: ↑Wed May 29, 2024 9:57 amI'd like a similar adapter which takes an mSATA SSD like the one that fits in the WWAN slot. Does such an adapter exist?
Also, regarding that Thinkmods NVMe adapter, don't get it. The owner has been MIA for a while: https://www.reddit.com/r/thinkpad/comme ... thinkmods/
Someone tested a different adapter: https://ounapuu.ee/posts/2022/10/04/tes ... d-adapter/
br1anstorm
Thanks @axur-delmeria, that helps to clarify things a bit.
Just to add to the information, my enquiry was prompted in part by seeing this YouTube video https://youtu.be/cfi-GSLijG8?si=XopTKPqwDMlHzwex.
I wasn't looking to try the NVME option, which seemed to be a step further (and perhaps more of a mod) than just adding an mSATA SSD. And I thought that physically, an mSATA SSD might be more compact and so easier to fit into an Expresscard casing than an NVME drive.
But if no-one has tried it and there is no source of supply (not even AliExpress from China) then it does look like a non-starter.
An mSATA SSD is physically larger than an M.2 2242 SSD, as seen in this photo:
Top left: M.2 2242 SSD
Top right: mSATA SSD
Bottom: M.2 2280 SSD
Unless you're thinking of a half-length mSATA SSD, though AFAIK these are less common.
Expresscard to nvme works well for me, the adapter is $30 or so on ebay and aliexpress and small 2230 nvmes are affordable on ebay. Biggest ive gotten is 512gb but they go up to 2tb i think at a large premium.
sent from my iPhone
That's a T430, not T430s, right? So it should have an SDXC slot where you could fit an SDXC card up to 2TB, I believe.
I used the ExpressCard slot on my W500 to add 2 x USB 3 ports. The card sits flush with the case so I don't have to worry about knocking it around, unlike something that protrudes.
kfzhu1229
Have you tried perhaps buying a large sized sdcard and leave it permanently plugged inside? I do that all the time on my devices that the sdcard inserts all the way with, this way if I want to try out another laptop and want much of my data with it, I can quickly do so.br1anstorm wrote: ↑Wed May 29, 2024 9:10 amDoesn't have to be bootable - it could just provide storage capacity for data.
600 PII-266 416mb 40gb WXP
T23 PIII 1.13ghz 1gb W7
T530i 15.6" i7 16gb fp W10
UXGA:
A30p PIII 1.2 1gb W7 (IDTech)
T43p 2.26 2gb fp W10 (Sharp)
UXGA:
Jake.Werecat
Why tinker so much? Wouldn't it be easier to just get a standard 2.5" SATA SSD with 2,4 or 8TB of space? Those are easily accessable, not so darn expensive anymore and work with not extra modifications and no problems.
T14 1st gen
Can X1-E Gen2 use DDR4-3200?
by Thinkpad2024 » Mon Dec 01, 2025 5:27 pm » in ThinkPad X1 / X1-Carbon / X1-Extreme and later Series - 1 Replies
- 4478 Views
Last post by dcfbf
Mon Dec 01, 2025 6:01 pm
M.2 SSD in P14s Gen 3 (Intel) (21AK)'s WWAN slot
by usescomputers » Sat Jan 24, 2026 5:57 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 0 Replies
- 4942 Views
Last post by usescomputers
Installing SSD in WLAN slot on E14 Gen 3
by catback » Sun Mar 29, 2026 12:05 pm » in ThinkPad Edge / E-series - 0 Replies
- 1560 Views
Last post by catback
T430 and bloody bluetooth
by jronald » Sun Dec 14, 2025 12:01 pm » in ThinkPad T430-T495 / T530-T590 Series - 1 Replies
- 3913 Views
Last post by ZaZ
Mon Dec 15, 2025 2:18 am
Users browsing this forum: PhoenixR and 63 guests
