Thinkpad 750C I9990303 error (SOLVED)
Hi guys,
Another example of a Thinkpad 750c with error i9990303. In the manual this refers to a faulty system board. The strange thing is it will boot from a floppy i created for a bios update. The program is called: System Program Service Diskette Version 1.43. I can select "2. Update system program". When i try to start i get an error "The system power management is disabled. The process has been canceled." I think this has something to do with a battery wich is not connected, but is there anyone with the same experience and possible solution?
Greets EJP
Greets EJP
Re: Thinkpad 750C I9990303 error
If it can boot from a floppy then try a bootable dos diskette.
I just purchased a 750C on eBay with a cracked display, when I attached it to an external display and powered it on it gave me 161, 8611 and 163 POST codes, then went to the I9990303 error page. Similar to your case, I can boot from the IBM Thinkpad System Service Diskette version 1.42 but not from a "normal" bootable diskette. I'm working on charging a "previously good" battery pack which was down to 4.89V so I've got the 750C "tied up" at the moment, but I suspect that if you download the REFSTAMP utility from the Ardent Tools (https://www.ardent-tool.com/utils/refstamp.html) and run it against your bootable diskette, then that diskette will boot on your 750C.
Thnx! I will try this as soon as i have time.
It works!!! Thank you very much for this. It boots from a win98 bootdisk and i can read the files on the c drive. Next thing is getting it to work without bootdisk but i am already happy this thing works!
W520 doesn't boot after critical battery error...
by salzrat » Mon Mar 16, 2026 12:18 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 12 Replies
- 5148 Views
Fri Mar 20, 2026 1:32 pm
T420 BIOS update fails with "BIOS directory not found" error
by FastCabbage » Mon Apr 20, 2026 3:40 pm » in ThinkPad T400/T410/T420 and T500/T510/T520 Series - 0 Replies
- 74 Views
Last post by FastCabbage
Thinkpad Helix 2 - Old Bios (1.77) Update (2.16-2020) done ...
by friedrich-eugen » Sun Oct 26, 2025 9:31 am » in ThinkPad/Ideapad Tablets & Convertibles - 0 Replies
- 10762 Views
Last post by friedrich-eugen
Model Recommendation For A ThinkPad Newbie
by onetr » Sun Oct 26, 2025 9:39 pm » in GENERAL ThinkPad News/Comments & Questions - 4 Replies
- 7822 Views
Last post by Bionicman
Sun Nov 16, 2025 11:26 am
Users browsing this forum: No registered users and 114 guests
