The laptop will quickly turn on and off twice before turning on for a third time and staying on with a blank screen and solid white power light. The fans will rev up from time to time but the laptop seems to be bricked.
So far I've tried
-unplugging the CMOS battery
-Unplugging the laptop battery
-removing the RAM
-holding down the reset button on the motherboard
So far I've had no luck an have no idea what went wrong.
X1 extreme gen 2 no splash screen
independent
Re: X1 extreme gen 2 no splash screen
Not a lot of info. Any evidence of a sudden shock to the laptop. IE broken plastics?
I would unplug the battery/s. You may need to visit a YT tutorial to figure out how to do that. Take out the memory (carefully, ground yourself first, don't touch the pins). Hold down the power switch for 30 seconds. Put everything back together--carefully.
Good luck. Let us know how you get on.
Freshman GNU/Linux member since 2007!
I let it sit at the blank screen for a little while and when i checked up on it nothing changed except the laptop was hot to the touch. I gave it one last shot and turned it off and back on and it magically came back to life. Went into the diagnostic menu and did a motherboard test, everything checked out. I have no clue what would cause the laptop to act like that.
It's called 'gremlins'.
- 13292 Views
Last post by Scorpion8
Wed Nov 19, 2025 4:42 pm
T14 Gen 3 compatible 40-pin 4-lane display cables
by LimesKey » Fri Oct 24, 2025 3:22 pm » in Thinkpad T14/T15/T16 - 3 Replies
- 8234 Views
Sun Oct 26, 2025 12:57 am
T14 Gen 1 AMD - problems with wwan card: whitelist?
by piripuz » Mon Nov 17, 2025 4:42 am » in Thinkpad T14/T15/T16 - 4 Replies
- 10532 Views
Last post by piripuz
Wed Nov 19, 2025 5:56 am
Why is my P1 Gen 7 so much better on battery? Cool, quiet, fast — but not on AC.
by Frippe » Tue Nov 18, 2025 5:21 am » in ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series - 3 Replies
- 9356 Views
Wed Nov 19, 2025 12:30 am
