Unable to install win 10 on thinkpad x61s
I want to install Windows 10 on my ThinkPad X61s but I don't get far in the installer as i get the "A media driver your computer needs is missing" error. I've tried most of the solutions like unplugging and plugging back in the usb, I've tried the solutions given on many websites, but I still didn't fix the error. I thought that i might get the driver itself, but I don't know which is the driver. If someone could tell me which driver for the ThinkPad X61s I would need, that would be nice.
I'm the original owner of a(n unmodded) ThinkPad X61s (2009).
specs:
Intel Core 2 Duo L7500 @1.60GHz
4GB DDR2 RAM @667 MHz
480 GB Crucial BX500 SSD
1024*768 display(original)
Intel GMA X3100 iGPU
specs:
Re: Unable to install win 10 on thinkpad x61s
Try adding the Chipset and Sata Drivers.
Thinkpads
R51 1829-W1C 2GB RAM
R500 2716-RY6 8GB RAM
T520i 4239-47U, 16GB RAM
T530 RIP
P15 G2 20YR 16GB RAM
SK-8835 Ultranav keyboard Japanese layout
T530 RIP
could you please link the drivers? its hard to find for me.
specs:
specs:
Thinkpads
T530 RIP
T530 RIP
Thanks, I'll ckeck if the problem is fixed.
specs:
specs:
It didn't work. Should I just install windows 7 and then upgrade to windows 10?
specs:
specs:
While I have not tried to install Windows 10 on the X61s in particular, that error typically will happen if the USB flash drive cannot be found. If you've tried multiple USB ports, try a different USB flash drive, and perhaps use a different Windows 10 ISO if the problem persists.
I don't believe the X61s should need any special drivers for Windows 10, so that shouldn't be the issue. From what I've seen, this is not what will happen with a hard drive error, but rather it's accessing the installer source files. If it can't find the hard drive then it'll specifically say 'no drives found.' (Of course, weird things happen and I could be mistaken - I can only provide advice based upon my own experience.)
Technical explanation: When you boot from the flash drive, the BIOS knows how to find the boot files, but once the file is booted, the boot files have to then find their way to the installation source files again because the BIOS isn't smart enough to do that. If it can't find them, this is what you'll see.
And on a last note, you could try the upgrade but I suspect you'll run into the same problem. I'd make a full disk backup first in case anything goes awry.
Good luck to you!
Good luck to you!
Sorry for the late reply, I had forgotten about this websiteracecar56 wrote: ↑Wed Oct 16, 2024 10:59 amWhile I have not tried to install Windows 10 on the X61s in particular, that error typically will happen if the USB flash drive cannot be found. If you've tried multiple USB ports, try a different USB flash drive, and perhaps use a different Windows 10 ISO if the problem persists.
Good luck to you!
specs:
specs:
WTB: ThinkPad with 32GB RAM, and 512GB SSD, Win 11 Pro
by Oswego » Mon Feb 16, 2026 1:53 am » in Marketplace - Forum Members only - 3 Replies
- 3297 Views
Last post by 28CarsLater
Thu Feb 26, 2026 2:01 pm
- 8 Replies
- 15453 Views
Last post by Loci
Fri Oct 31, 2025 3:02 pm
Display brightness issue with Win 10 on W520
by jdwis » Tue Nov 04, 2025 2:22 pm » in ThinkPad W500/W510/W520 and W700/W701 Series - 4 Replies
- 17132 Views
Last post by jdwis
Thu Nov 13, 2025 8:05 am
X61s screen backlight doesn't work. Faulty mobo?
by huohuo » Tue Mar 03, 2026 6:35 pm » in Thinkpad X60/X61 Series incl. Tablets - 4 Replies
- 6725 Views
Last post by huohuo
Sat Apr 04, 2026 3:43 pm
