Upgrade to Win 11 for X220 x230 T420s ??
Windows 1x on Thinkpads
mpcook
#1 Post by mpcook » Sun Sep 29, 2024 1:29 pm
I am sure there is a simple answer to this question but I cannot find it through search. I would like to upgrade a laptop to Windows 11. I have x220, T420s and X230 to choose from. I have been able to find a few bits of info about a registry change, which I did on the X230. Next I tried (1) download and install the Installation Assistant from MS Website. This results in the error "does not meet minimum requirements". Next I tried to create installation media, it gave me an error as well. Any easy way to do this? I chose the X230 just because it was "slightly" more modern than the other choices.
Current: X230 i5, T420s, DellVenue11, DellXPS8930, X1 Yoga 3GEN, X1 Yoga 6GEN
Past: IBM5150-8088 500 600E 600X T20 T21 5xT23 X30 3xX31 X32 T40 T42 3xT43 T43p SL510 T60p X60T X60s T61 2xT400 T410si T400s T500-3.06GHz X200 X201 X220i5 3xX220i7 2xT420s 2xW520
Re: Upgrade to Win 11 for X220 x230 T420s ??
#2 Post by axur-delmeria » Sun Sep 29, 2024 2:13 pm
Use Rufus to create the Windows 11 installer disk.
mpcook
#3 Post by mpcook » Sun Sep 29, 2024 3:15 pm
Thanks, any helpful hints on how to set up the install. I downloaded Rufus, created a Windows 11 disk on a memory stick. Tried to install and I am told my drive cannot be used as it is MBR. And now Windows 10 will not boot.
#4 Post by axur-delmeria » Sun Sep 29, 2024 9:12 pm
IIRC Win 11 requires UEFI mode (set the BIOS to either prefer UEFI boot devices or exclude legacy boot entirely) and GPT-formatted disks, so you'll need to convert the disk partition from MBR. I rarely do that because I just wipe the first 100 megabytes of the disk to effectively wipe any boot sector and partition table info (using the dd command on Linux).
That said, here's a guide from Microsoft's website:
https://learn.microsoft.com/en-us/windo ... a-gpt-disk
Puppy
#5 Post by Puppy » Tue Feb 11, 2025 2:49 am
I did inplace Windows 11 update (from Windows 10) on my X220 last week and was surprised how smooth it was. I was waiting with the update till 2025, because I believe the update process will be more polished now. Everything works, including the WWAN modem and fingerprint sensor. I removed all the Lenovo software long time ago, no crappy 3rd party antivirus software installed.
ThinkPad (1992 - 2012): R51, X31, X220
Huawei MateBook 13
Return to “Windows 10/11/etc.”
