After installing the SSD and RAM, I set up Windows on a USB stick, which booted fine. However, after completing the installation, the system crashed with a BSOD, usually showing the error "Critical Process Died," although I've also encountered other BSODs (see pics). I tried reinstalling Windows multiple times, but unfortunately, I kept encountering the same issue. Once, I managed to get it through the setup process and even used it for 5–10 minutes, but then it froze and crashed again.
I've tried a number of troubleshooting steps: swapping the RAM, running the system with only one stick of RAM, and running MemTest (which showed no errors). I even replaced the thermal paste, but the issue persists. Every time it boots into Windows, it crashes. A few times, I've managed to get it running for a few minutes, but it always crashes again. I even flashed the BIOS, but nothing seems to help.
At this point, I'm out of ideas and considering just giving up. Has anyone here encountered a similar problem or have any suggestions on what else I could try? I’d really like to get this laptop working again, as it’s still in decent physical condition.
