Do P1 Gen1 or P1 Gen3 have LE Audio support?
P1/P14/P15/P16/P40/P50/P70 Series
Muse
#1 Post by Muse » Mon Nov 25, 2024 3:43 pm
I have these two laptops, but are still running Windows 10. I have some issues I've simply lived with that may well be resolved if I upgrade to Windows 11. Presumably LE Audio is not possible with Windows 10, but may be with Windows 11.
If I upgrade to Windows 11 will LE Audio be available to me? I'm being fitted for Rexton Reach hearing aids in 10 days or so, which are LE Audio supporting with a recent firmware upgrade. Am shopping for a new cell phone that is LE Audio supporting, possibly a Pixel 8 or Samsung 23.
Thanks for info!
Muse
Re: Do P1 Gen1 or P1 Gen3 have LE Audio support?
#2 Post by Muse » Wed Dec 04, 2024 2:21 pm
What is clear is that the Bluetooth 5.0 which both of these Thinkpads came with will not support LE Audio. So, in hopes that the P1 Gen 3 and P1 Gen1 laptops WILL support LE Audio with the addition of Bluetooth 5.3 WIFI/Bluetooth cards I ordered a couple of these:
WAVLINK Lot Intel AX210NEW 5400Mbps Tri-Band Ethernet Network Adapter 2.4G/5G/6G
https://www.ebay.com/itm/387465694705
Is it possible one or both of these laptops will support LE Audio when I swap out the WIFI/Bluetooth card for these? I think the Thinkpads' audio codecs would need to be compliant, don't know how to evaluate that or if there's a workaround.
Edit: Or is a dongle possible that will make my P1 laptops LE Audio (and even Auracast) capable?
Hints/help/ideas appreciated.
Return to “ThinkPad P1/P14/P15/P16/P40/P50/P70 and later Series”
